Question about Saws
Do you have an extra set rails for hitchi table saw modle clofl table saw
SOURCE: Can I mount a Delta 36-T30 T2 30-Inch Fence and Rail System on my
I just installed a Delta T2 fence on my 10" Craftsman Table Saw. It's 27" deep. The bushing either could be relocated or you could use spacers on the front, back, or both on the saw to get the required distance. Also, you'll have to drill new holes, however, I used one of the existing holes in the front and back of my saw as well.
Posted on May 15, 2009
  • 8404 Answers
SOURCE: Ryobi 10 in Portable Table Saw modl #BTS12S won't turn on
Look for a trip switch on the saw motor
Posted on Nov 02, 2009
hondo73162
  • 132 Answers
SOURCE: I HAVE A BLACK @ DECKER BDTS200 TABLE SAW I WOULD
try looking at toolbarn.com they have alot of parts for almost anything
Posted on Nov 12, 2009
  • 760 Answers
SOURCE: I AM LOOKING FOR A MOTOR FOR A 10'' table saw
If you go to www.searspartsdirect.com and put in the model number of your saw you should be able to get one there. I don't believe that is the correct model number of your saw. Perhaps that was the model number of the motor. Does it look like this one?
http://www.joc-motor.com/product/234-universal-motors-joc-rm871-5994/
Posted on Oct 14, 2010
puertobori
  • 7733 Answers
SOURCE: does t2-30 rail holes match a delta 36-650 table
Look at eReplacementParts.com and the parts diagrams
Posted on Nov 09, 2010
I need a fence for a Yuan Huey (Sakura) table saw, model YHS-258AO. Any idea where I could get one?
I don't know of a source.
Table saw fences/rails are often interchangeable between table saw brands. Usually the rails that the fence rides on must go with the fence. The simpler the connection, the more likely a transfer is compatible.
Sep 30, 2014 | Saws
The rail on my FKS/E Proxxon table saw splays out at the end so precise straight cuts are difficult. Is there an attachment available to clamp on for the full length of the table, or some other way to
There should be a screw on the front end of the rail that can be loosened and adjust the guide straight and then retighten. Sometimes the screws are on top of the guide to do the same thing..
Mar 17, 2014 | Proxxon 38070 FKS/E Table Saw
N eed a better manual or some help on putting my table together 36-681
http://www.ereplacementparts.com/delta-parts-c-3275.html
Apr 09, 2012 | Delta U30 30' Unifence
Rip capacity is too small (24
If you can locate an old Delta Fence, I have seen those transplanted to a number of other table saws quite easily and reliably.
Otherwise aftermarket, there is the Beismeyer fence, it was adopted by Delta and licensed. You can get them through Delta or even Amazon. There are other vendors. You will want to add outfeed tables and extension tables as well.
You did not indicate which saw you have, but in general terms this applies to most saws.
Feb 14, 2012 | Saws
How do you square a miter gauage on a 10" sears
I just turn it upside down and put it in the slot so that the gage rests against the edge of the table. Then tighten the locking knob. This should give you an instant accurate setting as long as the slot in the table is very close to dead-on square with the slot - which it should be. But to verify that it is, just turn the square back right side up and hold a flashlight under it as you hold it very close to the table edge. If the table edge is out of square with the table slot, you will easily see this because the error will be doubled by turning the gage over. By the way, if the rails for your rip fence are in the way, the rails may be parallel enough to the edge of the table to be of no concern. Or you can put a piece of wood with parallel sides on top of the rail between the edge of the table and the upside-down gage. Another easy confirmation is to use a square to draw a line (with a sharp pencil) on a piece of plywood that has a good edge. Flip that square over to confirm that your square is square. Then you can put your miter gage upside down on the plywood to check it against the line. Good luck. Al K
Mar 02, 2011 | Craftsman 10" Table Saw
I AM LOOKING FOR A MOTOR FOR A 10'' table saw modle#rm 871 1ph 120v amps13 rpm 5000 yr 1999/6
Oct 14, 2010 | Craftsman 10" Table Saw
Nov 02, 2009 | Saws
Fence won't lock on rear rail.
Before I can assist You, I need you to provide some more Information.
Make, Model, & Serial # of Table Saw? Is this Fence the Standard that came with the Saw? What type of "Rear Rail" do you have? What "Rod" are you referring too?
Apr 03, 2009 | Saws
Mar 11, 2009 | Delta 36 T30 T2 30 Inch Fence And Rail...
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
