Question about The Office Equipment & Supplies
I am doing work with a KIP 2050 scanner. The sheets I am scanning have red and blue lines on with letters between the grids. The letters appear to be dark enough but the lines are to light.
tom19511
  • 1601 Answers
SOURCE: Fine tuning grid on my Samsung HDTV with remote.(BP59-00048)
To adjust manual convergence on your projection TV, follow theses steps:
  1. Turn your TV on.
  2. Let it warm up for 30 minutes.
  3. Press the Menu button on your remote. The Main menu appears.
  4. Use your remote to select Function, and then press the joystick.
  5. Select Convergence, and then press the joystick. The Manual Convergence screen appears.
  6. Select Red, and then press the joystick. A series of crosshairs appears on the screen.
  7. Select one of the outside crosshairs by moving the joystick up/down/right/left or by pressing the 2 (up), 4 (left), 6 (right), or 8 (down) buttons on your remote. The method you use depends on the model of remote you have. Note: You must do the outside crosshairs first.
  1. In the crosshair you selected, if you can see a horizontal red line, use the CH up or CH down buttons to move the line so that it is superimposed on the horizontal center line of the crosshair. Note: Make the single horizontal line as white as possible.
  1. In the crosshair you selected, if you can see a vertical red line, use the Vol + or Vol - buttons to move the line so that it is superimposed on the vertical center line of the crosshair. Note: Make the single vertical line as white as possible.
  1. Repeat for all outside crosshairs, and then for the inside crosshair.
  2. Return to the Manual Convergence Screen, and select Blue, and then press the joystick.
  3. Repeat Steps 7 through 10 for Blue.
  4. Press the Menu button on your remote to exit.
Important: The directions above work for most Samsung Rear Projection TVs. Yours may be different. For exact directions to perform manual convergence, see your user's manual. If you don't have your user's manual on hand, click HERE to view your manual on line.
If you cannot get your Projection TV to converge, it may need to be serviced. To arrange a service appointment, call Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your TV's model number and serial number on hand when you call.
Posted on Jan 05, 2008
mohanchennai
  • 490 Answers
SOURCE: Lines across scan
It appears to be a freak problem. The best way is to bring it to original condition. Try uninstalling the scanner, run Scandisk on the Comp, Switch off and reinstall the driver. this may work.
S. Mohan
Posted on Feb 13, 2009
SOURCE: A Dark Vertical line appears 1 inch into the left side of scan
Most Mustek scanners have a black inside cover on the lid, this can give a black line down the side of the job.
ether cover the inside of the lid with white paper or place a bigger sheet on top of the sheet to be scanned!
Posted on Feb 28, 2009
  • 19 Answers
SOURCE: Scanned pictures has thin blue line running through it
I had the same problem with My Espon Perfection V500. I called tech support and they had me do the following sequence.
1. Turn off the unit
2. Unplug the lid from the base
3. Replug in the lid.
4. Turn the unit back on
5. Go into the Epson software in Professional mode, Configuration, Other and select Reset All
6. Rescan the picture.
It worked after that. Of course it also lost all my preset sizes in my Custom box and any other settings I had. I suspect the lid plug is what the problem was.
Another word to the wise. To test it I put in a picture that was laying on my desk and rescanned it and was disappointed to see the line in the result. A few minutes later I discovered that this particular line was in the original picture.
Posted on Apr 18, 2009
mohanchennai
  • 490 Answers
SOURCE: Line appears on all scanned documents. Scaning window & rollers have been cleaned.
Do the lines appear in the same location on all images? Please clean the glass with isopropyl alcohol.IF the lines are crisp and sharp at the edges on all levels of contrast, then it is module problem. If it varies depending upon the contrast chosen and is also with jaggered edges, it is dust stuck on the glass. Dont use solvents.
S. Mohan, Chennai, India
Posted on Jun 09, 2009
Unable to scan legal pages from feeder
Hi Nicole,
Improve the FixYa experience for everyone by voting.
There are two (2) things that I want you to try.
First, run the HP Scan Diagnostic Utility: CLICK HERE
Second, run the Microsoft diagnostic scanner. CLICK HERE
Hopefully, if you have a firmware or software problem, these two self-explanatory apps will solve your problem(s).
All the best,
May 08, 2012 | HP Officejet J4680 All-in-one Printer...
Hello, I am having a problem with a newly bought HP deskjet 2050 all in one; when scanning some of the documents end up with ~1inch cut off even though they are standard letter size. Any suggestions?
Make sure you are placing the page in the scanner properly, most will indicate what corner/edge the scanner begins scanning from, you may also try checking the settings for the scanning software to make sure its set to letter, or try setting it to legal if its already set to letter.
May 29, 2011 | Office Equipment & Supplies
Canoscan d1250 u2f red and green lines
Normaly Red Green or Blue lines appear because of Dust in the CCD or due to electronics Failure. If this problem had happened after some SW changes then Try connecting the Scanner to a different Machine.
May 31, 2009 | Canon CanoScan D1250U2F Flatbed Scanner
Color distortion with HP 2300 scanner
Hp scanner 2300c
while scanning a blue or red line appears on scanned imajes
Mar 17, 2009 | HP ScanJet 2300C Flatbed Scanner
Lines across scan
S. Mohan
Feb 12, 2009 | Microtek ScanMaker 9800XL Flatbed Scanner
Mustek Scan Express A3 USB Scanner
I've had a similar problem with the streaks, lines and color bleeds appearing in the scan. Try uninstalling the all software and drivers for the scanner and reinstall. Worked for me. Have had to do this a couple of times since I've owned the scanner... about three to four years now.
Jan 25, 2009 | Mustek A3 USB Flatbed Scanner
Jan 24, 2009 | Mustek A3 USB Flatbed Scanner
Red and blue marks on copies
The CS 2050 is a mono color (black only) copier. There is nothing within this machine that I have EVER seen that has red and blue "ink" in it. I suggest you look at the paper that is in the tray itself. I have been on many service calls where the customer said the copier was tearing off a diagonal corner of the page, or the copier was putting something on the page that it was not capable of doing. When I looked at the paper in the tray I would find that the paper itself had the defect before it ever even went through the machine. Since there is 500 sheets per ****, and you may only see it on every 20th or 30th copy, you will have to either just try a new **** or go through whats in there 1 sheet at a time looking at both sides. But, if you find something that has blue and red ink within this machine please let me know.
Nov 24, 2008 | Copystar CS-2050 All-In-One Printer
19 people viewed this question
Top The Office Equipment & Supplies Experts
Gareth Cockram
Gareth Cockram
Tygh Duval
Tygh Duval
Jerry Greenberg
Jerry Greenberg
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
