Question about Toro Garden
Toro zero turn been setting for years, got it to turn over found out that its been reag to much that it wont stay running.have no manual
  • 246 Answers
SOURCE: bought a 2002 toro timecutter 18-52 zero turn lawn
Hello:
>>You can View a Breakdown/IPL of the Mower at this Site Addy, https://lookup3.toro.com/partdex/default.cfm and Select Start Parts Viewer. Now Enter the Model Numbers () and Click Search. Now Select View Assembly Drawings for your Year Model.
At the Bottom of the Page (#6), Use this Link to Locate your Local Toro Dealer who can Order the Manual for you or you can Contact Toro Using the Options at this Site Addy; http://www.toro.com/contact/Homeowner.html .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
huffman49
  • 235 Answers
SOURCE: replace valve guide seals toro zero turn
i don't think those are replacable i may be wrong but i have never replaced valve guides in a small engine about the only thing that can be done is grounding the valve seats and lap the valves into the new seats..good luck
Posted on Apr 14, 2010
  • 10865 Answers
SOURCE: 2009 31cc toro weed eater wont stay running. will
get a can of starter fluid and a helper. Start the weed eater and then squirt enough starter fluid into the air intake to keep it running while you move it through the settings. This will rid your tool of the crud that is causing your problem. Joe
Posted on May 07, 2010
BAMOUT
  • 2478 Answers
SOURCE: carburtor problems with toro tecumseh h35-45598R 5231B ser# it wont stay running
Posted on Nov 15, 2011
mirab327
SOURCE: My 42" toro zero turn
the drive belt pulley probably needs replacing or the belt popped off the pully
Posted on Aug 08, 2012
How to troubleshoot my Toro MX5060 when it doesn't start?
thats a zero turn mower... are you sure this is your mower ???
Sep 03, 2014 | Toro TimeCutter MX5060 - 23HP 50 Zero Turn...
Mower wont turnover at key switch
Mower has multiple safety switches, seat,&hydraulics, also a bad PTO switch will cause them not to start.
Jun 19, 2014 | Toro 52" 27hp Z Master Zero Turn Lawn...
Toro 22 hp kawasaki starting problems
sounds like the float is stuck to me . take carb apart and clean and reassemble
May 25, 2013 | Toro 42 In 22 Hp Kawasaki Vtwin...
Toro timecutter mower motor upgrade
90% of vertical shaft engines use the same pattern only seen a couple that one hole is off place
Sep 13, 2012 | Toro 52" 27hp Z Master Zero Turn Lawn...
Have a 3 year old 42'' Toro Zero Turn never had a problem. Was cutting grass and it died. Will not start, no fire and does not seem as if it is getting fuel ? Does it have a fuel pump or could it be...
That unit has a fuel solenoid that is attached to the carburetor bowl. Over time this solenoid can act up at odd times. You can take off the air filter cover and manually choke the unit and see if it will start up again. I would take it in to your nearest TORO dealer. On the website it has a dealer locator to find the closest one to your zip code.
Mar 28, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
The steering levers quit working on my zero turn Toro Timecutter 16-44.
My steering levers on my zero turn toro quite working, The mower wont go forward or in reverse any ideas on how to fix this.
Jun 12, 2010 | Garden
2009 31cc toro weed eater wont stay running. will fire and run at idle but wont stay running in 1,2,3 settings
May 07, 2010 | Garden
Garden Logo
24 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
