Question about Frigidaire FGF337 Dual Fuel (Electric and Gas) Kitchen Range
Oven won't heat
When we turn the oven on, it clicks but won't heat up. What could be the problem?
  • Frigidaire Master
  • 3,361 Answers
Check the glow bar ignitor. Is it glowing? If not replace it.
Posted on Aug 02, 2009
Oven won heat unless burner is on
Check the oven ignitor, it may be bad. See if you have power going to the ignitor.
Oct 23, 2013 | Samsung RGSF5330DT Gas Kitchen Range
Microwave won't heat
This is very likely a faulty Magnetron especially as there is not heat. To repair this would mean replacing the Magnetron which is a fairly standard repair for a Microwave oven
Nov 26, 2012 | Microwave Ovens
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
Whirlpool oven won't heat after power outage
you will have to press the hand on your timer it needs to be set back on manual its on time cook you will hear it click back and your oven light will come on and heat read how to in the book that came with your oven
Nov 06, 2011 | Ovens
My oven stopped heating, and the range element won't turn red when you turn it on but it does have some heat coming from it. What's wrong with it?
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 [
Aug 08, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
My GE gas oven won't heat up. The stove top and broiler work fine but when I turn the oven on, nothing.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 03, 2011 | Microwave Ovens
Oven won't heat, all burners work
I suggest that you remove the upper and lower heating elements to the oven, turn the oven switch to on, then use a good digital voltmeter, and check the plug that the lower heating element was in. If you have good (200 volts or more) then purchase and install new heating elements. Turn the oven switch to Broil setting and check the same way for the top heating element.
May 09, 2011 | Maytag Kitchen Ranges
MY GAS OVEN WON"T TURN ON, IT MAKES ONE CLICK AND YOU CAN SEE SOMETHING GLOWING IN THERE BUT DOESN"T COME ON
Just because it glows that does not mean it is not bad...
heatman101
Sep 18, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire FGF337 Dual Fuel (Electric and Gas) Kitchen Range Logo
137 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
