Question about Dryers
Power is good on my dryer, timer is ticking when turned on, pressed the start button and got nothing
In time past the dryer continued to run when the door was opened
  • 146 Answers
Door switch is probably full of lint . May need to replace it.
Posted on May 16, 2017
When the timer on an electric dryer fails to start the dryer. Should you still be able to hear it ticking, when the timer is turned on?
Of course. Correct diagnosis is the key to such things. All the items you swapped out were fine. There are checks you can make with all those components. The rotary type timer is just a clock timer like a wind-up alarm clock. When you turn them on, they tick. In normal circumstances, turning it on will start the machine, and not count down. You need to remove it and make sure you have continuity and also power to the timer. There is more to this than meets the eye. The other item that it may be, is the motor itself.
Nov 25, 2017 | Dryers
Dryer doesn't start
Actually, it's probably the switch under the button meeting its demise.
Jan 14, 2018 | Whirlpool Dryers
Dryer will not start but timer ticking
If the start button is an "ON - OFF" button (meaning, you can turn the dryer off manually instead of resetting timer in order to switch it off), try turning the dryer ON...then switch it back to "OFF".
Hopefully the dryer will continue, and the thermostat will kick in.
Dec 01, 2013 | Dryers
Dryer won't come on door is closed timer ticks the
you need to open front panel or top, depends on brand and model...
you will see door switch there, to check you will need electrical meeter, unplug from power before opening it.
check continuity of switch, by pressing/depressing it.
if it's working than check start button switch if your model has it.
Jun 29, 2010 | Dryers
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer
Do you hear the timer ticking?
Make sure there is 220 volts present at the terminal where the cord hooks to the dryer.
Inspect the wires for loose or burned.
Check continuity on the door switch.
Check continuity on the start switch.
Mar 11, 2009 | Kenmore Dryers
Kenmore 90 series won't start timer ticks
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Dec 03, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
23 people viewed this question
Top Dryers Experts
