Question about Refrigerators
Fridge makes water and ice that tastes like dirt. Can not find a filter. Is the fridge too old? It is about 14 years old
  • 1,830 Answers
That is pretty old. What brand is it?
Posted on May 16, 2017
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
Water from the fridge tastes bad
How old are the water lines that run to the fridge? Is this a new fridge? Was the water good and now it is bad all of a sudden or is the first time using the water?
Jun 12, 2012 | LG Refrigerators
Ice from refrigerator taste like ammonia
very rarely does the fridge make the water taste bad, it is usually from the plumbing. First check if the fridge has a water filter and replace it if it's over a year old.
May 01, 2012 | Maytag Refrigerators
Fridge is one week old both water and ice have a metalic taste. My old fridge had no problem. The only change was I went from copper tubing to plastic.
You probably shook lose sediments that collected in your old water line. Flush as often as you can and the taste will dissipate soon. In other words; run the dickens out of the water and use up the ice to flush it out completely. You might also be tasting the newness of the ice maker and related components. Flush, flush, flush. Also helpful is to clean thoroughly with baking soda everything you can get to.
Jul 07, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice Machine's Ice and Water taste like mud!
go to sears.com enter the model number and you can get an owners manuel and should be able to order replacement filters.
Apr 25, 2009 | Refrigerators
Water and Ice in Door Tastes Awful!!!
If your water tastes ok without the fridge then you'll need to replace or clean the piping inside the fridge.
If your water has the same smell and taste without the fridge then you'll need a better grade filter on the water going into the fridge.
If it's in your fridge piping try going to a plumbing supply and ask them for a cleaner to run through the fridge!
jack
Mar 08, 2009 | Amana SXD524VW Side by Side Refrigerator
Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker's ice taste funny
You may consider pulling out the ice maker and tossing it in the trash if you look at it and see that where the ice sits it's corroded or its close to a 10 year old in age (IT'S DUE TO GO OUT ANYWAY).Other than that:you have a 3% chance that the tube that goes to your ice maker is bad. Please Rate This !
Jun 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Filtered Water tastes "off"
Could be something foreign in the water line on the fridge side...or somewhere in the ice maker/ water dispenser inside the fridge......when it tastes stale....maybe there is something maybe mold or something that is part of the plastic ????
I usually add an in-line filter to my water line before it reaches the fridge so that 99% of the elements are trapped before it gets to the fridge. My original filter is still good. Maybe someone needs to inspect the ice maker with a a bright light and an inspection mirror to see if there is any thing that looks suspicious....this is only a suggestion but leaving the line disconnected for so long could even cause something like a small insect to crawl inside the line...
Mar 06, 2017 | Kenmore 56872 / 56874 / 56876 / 56879
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
