Question about Sewing Machines
How do I fix a thread cutter that is jamming on the Elena Xpressive 820
2 Suggested Answers
99rannellis
  • 12278 Answers
SOURCE: My automatic thread cutter jams in the bobbin and will not cut thread. Everything else wotks fine. This is a singer quantom 9960, have had less than a month.
If it's a new machine, you may be able to take it back to the vendor. Otherwise, it is probably covered under warranty.
Posted on Mar 14, 2017
I have a Juki TL-98Q The thread cutter and the needle up down button don't work. How can I fix them?
Has a piece of broken needle or chunk of thread jammed into the blades and are not letting them move? If there was a big time thread jam it can actually break one of your blades and you will have to go to a repair man and have the blade replaced.
Jan 09, 2016 | Juki TL-98Q
The bobbin assembly has a lot of tangled up thread and is jammed. How do I clear it?
Avoid attempting to run the motor if the machine is bound--it may damage the motor.
Remove the presser foot and, if you can, remove the needle. Then remove the needle plate, the bobbincase, and the hook. If you are unable to remove some of them, you may need to use a small pair of scissors to snip the threads and gently pull them out with needlenose pliers or tweezers.
Once you have the thread tangle removed, clean with a soft brush to remove all the lint and thread bits and place a drop of good quality sewing machine oil (preferably Bernina oil for your machine) on the bobbin race. Install a brand new needle (in case the old one was damaged).. RAISE the presser foot, remove all the thread, and rethread from the very beginning. (The raised presser foot releases the tension disks so the thread will seat properly.) Use good quality thread--avoid old or bargain bin thread (some Berninas object strenuously to Coats & Clark thread too). Some threads create heavy lint buildup in the tension disks and bobbin area in addition to hanging up in the needle and elsewhere. Also, some fabrics shed more (ie fleece), so be sure to clean often. Try to oil your machine as instructed in the owner's manual--every time you change a bobbin, after 8 hours of constant sewing, or every 6 months if not in regular use.
When Thread is Caught in Sewing Machine Sewing Lessons
How to Fix Thread Jam Sewing Machine
Anyone have experience with jammed bernina sewing machine Discussions...
Having trouble with my new Bernina 820
This video may help avoid thread nesting:
How and Why to Bring up the Bobbin Thread
Oct 21, 2015 | Bernina Sewing Machines
Fix thread cutter on singer quantum xl 100
Is it blunt? Is it angled properly . these and needle threaders are a pain in the neck, I just use scissors and thread my own needles.
Best wishes
Jan 24, 2015 | Singer Sewing Machines
How do I fix automatic thread cutter on the brother PC 420?
I am not sure what to do about it. Did you try clean the shuttle real well? If that does not work, call Brother!
Oct 13, 2014 | Brother PC-420
Was sewing and the bobbin ran out and it seemed to jam, I used the cut thread button and it made a funny grinding sound, error appears. Turned off machine and it come on and still the grinding sound and...
Taking those parts out was a good idea. Some machines you can engage your thread cutter with the bobbin etc. removed. Try this . Make sure your presser foot is down and you fingers are out of the way. see if the sound is still there. if so, I would recomment you take it in for service. The jam could have knocked the cutter out of alignment.
Machine Tech
Oct 21, 2013 | Janome Sewing Machines
I have a Pfaff grand Quilter and my top thread is not catching the bobbin thread. When it does the stitches skips. Can anyone help!?
Hello
If you have changed the needle and rethreaded the machine, then take apart your bobbin and make certain there are no small pieces of thread or lint in it. Check your tension. Do you have an automatic thread cutter? I had the same problem and it was because my automatic thread cutter was cutting the thread too short. Some how the cutter had gotten bent...I could not tell it, but it was.I put the blade of a flat head screw driver under the cutter and GENTLY bent it back down. Fixed the problem. Works perfectly.
Jul 15, 2011 | Sewing Machines
I replaced the thread in my bobbin the same way i always do but i guess i did something wrong or by replacing it just made my problem stand out but now every time i go to sew, the top string gets cut on a...
That is your thread cutter. Depending on what machine you have, whether it is automatic thread cutter on an arm or just a manual one. If it is automatic, pop the cover off on the left top of machine next to the bobbin area. The arm should be seen there. It moves like an elbow. Push your thread cutter (scissor button) and watch how it works to see if it has come off the post. If you don't have automatic thread cutter, perhaps the thread cutter is not pushed all the way back in its place. The thread cutter looks like a triangular piece of flat razor. It could be sticking out too far or perhaps bent. I have fixed mine before, but be careful.
Feb 05, 2011 | Husqvarna Sewing Machines
Janome MemoryCraft 6500P auto cutter problem
I have never had this problem on any of the machines i have repaired.
What happens if you press the needle up/down button?
Feb 25, 2008 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
