Question about Kenmore Dryers
How to clean lint out of the inside of kenmore 90 series dryer
  • Kenmore Master
  • 1,830 Answers
Locate the lint filter. If you do not remember where it is check your owner's manual.
Posted on May 16, 2017
I have a ken series 90 has a lot of build up lint and i would like to know easiest way to get to the inside to clean out thanks
In the trap itself there is a flexible brush you can buy and reach in. As for the vent pipe you will have to remove and clean and replace it once cleaned.
Sep 26, 2012 | Kenmore Dryers
Kenmore 90 series electric dryer qiuet pak 1 101649022200 the lights are on when you open the dryer but the dryer itself will not turn on or do anything!
There's thermal fuse on the blower that blows when the cycling thermostat malfunctions or the lint/vent duct are blocked. This thermal fuse is wired in series with the dryer motor and if it blows, power to the motor is terminated causing the dryer not to start and no dryer function works. Check to make sure that the lint filter is always clean and the vents are clear. Click on the link below for the detailed troubleshooting of the dryer, particularly the thermal fuse, when it doesn't start.
Troubleshooting Not Starting Whirlpool and Kenmore Dryers with Lint Filter on Top
Feb 09, 2011 | Dryers
Need help with gas dryer Kenmore 90 series serial
Check the lint caught in the exhaust vents. If it is clear replace the spark ignitor if no click is hear upon starting up
May 14, 2010 | Kenmore 73952 Gas Dryer
Kenmore 70 series gas dryer (Whirlpool model) will not ignite!!!!
>> Do you know where the flame sensor is located? I figure the ignitor is where the "glowing" occurs and the gas line feeds to. Thanks for your help!<<
The flame sensor is right next to the ignitor. Also see this link for what it looks like:
http://www.apwagner.com/index.php?main_page=index&cPath=7_96
Mar 18, 2010 | Kenmore 73952 Gas Dryer
Have Kenmore 90 series elec. dryer...will start, but then cuts off and doesn't dry clothes. Trying to clean the lint out of it. We've taken all the screws out of the back, but can't get the back off!...
Hi-I just cleaned out mine. You take off the clamp that holds the exhaust duct from the bottom of the back of the dryer and you will be able to vacuum it out. Then you can remove the kickplate on the front of the dryer by lifting it hard and pull the top of it out. Then you can remove the lint trap holder once inside by unscrewing it, remove it and clean it out(take out the lint filter first). I vacuumed out the inside of the exposed bottom gently cause it was so full lint! Hope this helps!
Jan 23, 2010 | Kenmore Dryers
Kenmore series 90 electric dryer: exhaust air is
that's normal,obviously you haven't cleaned out your dryer and vent line,nobody ever tells the customer when you buy your dryer that it should be cleaned out at least once a year so you don't have a fire more so if it's a gas dryer with an open flame inside the dryer,you gotta vac out the inside where the motor is,clean out the duct that the lint filter slides into and blow out the vent line,i use a leaf blower to clean out the vent line,take it off the back of the dryer,stick the leaf blower in the line if it's a long run if it runs through the wall and to the outside flapper and blow all the **** out of it,also if you have a shop vac put it on blow and blow off the motor,you won't believe how much lint comes off the motor even though it looks clean,so vac out the inside of dryer,clean out the lint filter duct and blow out the vent line
Dec 18, 2009 | Kenmore Dryers
Kenmore 90 Series Dryer start button humms, but that's it.
MOTOR HAS GONE BAD,IF YOU WANT TO TACKLE IT THE MODEL NUMBER IS INSIDE THE DRYER DOOR,YOU MIGHT FIND A GOOD DEAL ON EBAY OR GO TO SEARS.COM UNDER APPLIANCES,LET ME KNOW AND I WILL HELP YOU WITH IT-MIKE
Mar 06, 2009 | Kenmore Dryers
My Kenmore 90 series dryer stopped running during cycle
IF YOU HAVE NOT CLEAN OUT THE LINT MOST PROVALY THE MOTOR IS FULL OF LINT AND IT GET HOT AND STOP.IT WENT IT COOLS DOWN IT STAR REPLACE THE MOTOR OR BUY A NEW 1 WILL CUST TO MUCH TO FIX.
Jan 24, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
