Need a hose for. The water to run in and out two feet long
My kreepy krauly wont clean the deep end of the swimming pool.
Your situation is unusual in that most of the time these will stay in the deep end and not get to the shallow end. Make sure that your hose is the proper length and the hose weights are in the right positions
Up to 4 feet water, 1 weight at one foot away from Kreepy
4-7 feet water, add a second weight at 6 feet from Kreepy
7-12 feet water add a third weight at 10 feet from Kreepy.
It can take some trial and error to get the Kreepy to cover the whole pool. This includes adding or removing hose sections, and adjusting the pool return "eyeballs" to different directions.
Feb 21, 2014 | Universal Kreepy Krauly In-Ground Pool...
Cold water runs slow need info on how to clean
to clean those screens turn off water supply to washer pull it away from the wall about 2 feet remove hoses from back of washer and be sure to note where the hot and cold goes use a small flatblade screwdriver and pop out screen inside of where hoses attatch at back of washer if cleaning does not work the part (water inlet valve) the screens are inside of will need to be replaced this video will show you how to replace that valve
Aug 10, 2011 | Roper Washing Machines
My washer drains while its filling
Raise your drain hose up to a higher level. The gravity is letting the water run out because the hose is too low. Drain hose must be at least 30 inches above the floor but no higher than 5 feet.
Apr 04, 2011 | Kenmore Washing Machines
Water coming out airbush from hose
An in-line water separator should be used before the supply line, a good air filter wouldn't hurt either.
Apr 23, 2010 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
My washing machine will not fill up with water. The water is running into the machine but never fills the machine. It seems like it is just running directly out again. I own a frigidaire top loading...
The drain hose must be higher than the tub. Had the drain hose at any point been lowered or dropped in such a way that it would be below the tub?
Dec 22, 2009 | Washing Machines
Maytag top load washer water runs but doesn't fill.
Drain is to low. You will have to raise the drain hose above the top of the washer. Whats happening is the water is siphoning out as fast as it goes in.
Please rate this solution
Sep 02, 2009 | Washing Machines
How many feet can a dish washer pump waste water horizontaly
Horizontal ,no problem 20-30' ,install check valve in line.Vertical max 6' feet.Please rate my response :)
Jun 20, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Continues to fill, not holding water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
If the above adjustment doesn't produce positive results, replace the control.
May 31, 2009 | Crosley Washing Machines
New 1/2 hp jet pump with tank not working
Your hose size is to small. Use a 2in black plastic line out to the lake. Inspect your foot valve, and
take your pump apart to see if you may have a pebble stuck in it, and remove the inner workings
and clean. Contaminates build up inside and need to be flushed out. Remember to replace the
gasket. Tighten all your hose clamps. Once your ready to start, spray shaving cream on your
fittings to see if your sucking air. I've been through it all and my pump works fine.
May 03, 2009 | Plumbing
I take it that you have tried rotating the cycle knob slowly through the point at the end of the wash cycle to the rinse cycle? On many machines, this will trigger the pump to drain the tub. Yet I am guessing that you have already tried that.
You could try running a garden hose from the machine along the floor and then outdoors. Next, take the end of the garden hose and place it into the top of the machine so that the end of the garden hose goes to the bottom of the tub. Feed in another five feet of garden hose into the machine so that this five feet is below the water level. Now, hold the palm of your hand over the end of the garden hose at the bottom of the machine and while doing this, pull out the extra five feet of garden hose and then remove your hand from the end of the garden hose. This should have "primed" the end of the garden hose with water so that the water will get sucked out of the machine and flow through the garden hose to the outdoors.
If this doesn't work, then you will need another person to **** on the other end of the garden hose in order to get the water to start flowing through the garden hose.
Apr 25, 2009 | Maytag MAH2400A Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
