Question about Cell Phones
Why is my notification screen jumping up and down constantly
How do I get rid of a silly graphic weather widget which overrides my weather photos after I accepted it?
Adding & Removing Widgets and Items from iOS Notification Center
Don't care to see Reminders or Stocks in your Notifications screen? You can add or remove anything:
  1. If you haven't already, unlock the iOS device swipe down to bring about Notifications panel
  2. Select the "Today" tab and choose "Edit" at the bottom of the list
    • Delete Widgets from Notifications: Tap the red (-) minus buttons alongside items to remove them from the Notification panel
    • Add Widgets to Notifications: Tap the green (+) plus button to add a widget to Notification Center
  3. Choose the "Done" button in the upper corner to set the changes in place
Any adjustments made to Notifications Center here will be visible when accessed from either the lock screen or elsewhere in iOS.
Dec 07, 2014 | Apple iPad 32 GB WiFi Tablet PC
How do I delete the call log on my LG F5 Optimus cellphone?
To clear all notifications
1. Open the Notifications panel.
2. Touch the Clear icon .
All event-based notifications will be cleared; ongoing notifications will
remain in the list.
TIP You can also swipe the notifications to the left or right to remove them.
To clear the call log - From the Home screen, touch the Phone Key (in the Quick Keys
bar) and then the Call logs tab at the top of the screen.
The most recent calls are located at the top of the list. Scroll down to
see older entries. Once you see the cal log press the Menu key. Bottom far right. This will give you the option to Clear all .
Sep 29, 2014 | Cell Phones
Samsung galaxy how do i delete my old notifications ive asked 30 times answer please
On a Galaxy S3, open the notification window by swiping your finger from the top of the main screen to the bottom. Near the top will be a bar labelled "Ongoing"; father down will be another bar labelled "Notifications". Tap on "Clear" on the "Notifications" bar to clear all the notifications below that bar (the "Ongoing" notifications will not be cleared.)
Notification Panel
May 23, 2014 | Cell Phones
How do I delete notifications on my Iphone 5?
Swipe the notification center down from the top of the screen and then double tap the notification.
Sep 18, 2013 | Computers & Internet
My digital dashboard speed notification is stopping and jumping from different numbers. and my gas notification is counting down by the seconds.
Run the fault codes and look for a faulty spend sensor. If the speed indicator is incorrect then the mileage counter will also be incorrect ant that means that the computer cannot accurately calculate the fuel consumption hence the faulty fuel notification. Fix the speedo sender unit and all the other problems should be corrected.
Aug 17, 2013 | Mercury Cars & Trucks
Iphone task and calendar alerts disappear when I enter password
Depending on the OS you are running they are in Notification Center(iOS 6 and Later). You can access Notification Center by swiping down from the very top of your screen in iOS 7. You can change Notifications on an app by app basis in Settings, Notification Center.
Jun 03, 2013 | Apple iPhone Cell Phones
Hi, my bb9000 consumes battery very fast please advice what should i do in this regard?
    • 1 Turn off your wireless and Bluetooth when they are not in use. If you leave your wireless settings on, your phone is constantly looking for a wireless connection, even if one isn't readily available. This eats up battery power. Touch "Manage Connections" from your home screen and select "Off" for wireless connection. Then turn your wireless on when you know a connection is available.
    • 2 Close applications when you're finished using them. Leaving applications running uses memory and battery power, especially if those applications send you frequent notifications, like Facebook. Once you're done using an application, use the Blackberry button and select "Close" at the bottom of the menu to close the app completely and avoid notifications until you open the app again.
    • 3 Use your applications wisely. If you're running short on battery life, it may not be a good time to run Google Maps or other applications that use a lot of battery power. In general, battery-consuming applications are those the need a constant internet or data connection and cause you to receive frequent notifications.
    • 4 Change your vibrate notifications so that they occur less frequently, and use audio notifications when you can. Vibration actually uses more battery life than a ring tone. While you may need to put your phone on vibrate when you need to use your phone discreetly, shortening the amount of vibration notifications you get can conserve battery life. Choose "Options" from your home screen, and then "Sounds and Ringtones." Choose "Ringtones" from the drop down menu and select the type of ringtone you want. To decrease the volume of your vibration -- and therefore the power you use -- press the volume buttons on the side of the phone when the phone is in vibrate mode.
    • 5 Decrease the backlight timeout, which keeps the keys on your Bold lit for a specified amount of time after you stop using them. The shorter the timeout, the less battery power you'll waste. Visit "Options" from your home screen and then choose "Screen/Keyboard." Adjust the backlight settings so you only have three to five second before timeout and the backlight shuts off. You can also use the settings to dim the backlight to use less power.
Read more: How to Optimize My Blackberry Bold's Battery Life '
Mar 22, 2011 | RIM BlackBerry Bold 9000 Smartphone
Droid (2 GB) Cell Phone: droid constantly makes noise - the droid sound, ho...
From the home screen, go to Settings> Sound & display> Notification ringtone> then you can select "Silent" if you don't want any "Droid" noises when you get text messages, etc., or you can select a different notification sound.
Hope that helps!
May 05, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
Jumping screen
If you have dropped the TV or it has been bumped significantly you may damaged part of the tv tube section where the electrons are beamed. Sounds like a damaged tube to me. If this occurs when you play a videocassette, you need to adjust the tracking of your videocassette player and the screen jumps will go away. I don't have that problem now, but on the bottom portion of the screen there is slight curvature distortion. In the late 1960's Sony TV's made the industry stand on its ear and could stop a shopper for clear across the showroom to take notice. Keep in mind our televisions are almost 20 years. It is "unheard" of for any tvs to last that long. Mine has lasted that long before developing the problem I posted on this e-bulletin board.
Dec 27, 2006 | Sony KV-27S42 27" TV
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
