Question about HP Boating
Where is fuse on 1989 90 hp evenrude - HP Boating
Looking for a wiring diagram for a 1985 85 hp evenrude
http://shop.evinrude.com/category/342499/Literature
try this web site. since I do not have enough info, maybe you can find what you are looking for on this site. Good Luck.
Aug 05, 2017 | HP Boating
15 hp evenrude he ran with bad impeller it overheted then shutdown i replaced impeller but it wont start. any suggestions???
an overheated engine will soften the rings so that the compression fails and may have damaged the reed valves that facilitate the compression
if it is a 4 stroke then there could be piston damage as well
If you do not have a workshop manual or are not mechanically conversant with engine repair then I recommend that you take it to an evenrude service dealer for diagnosis and repairs as there is a safety issue here
Sep 04, 2015 | Cars & Trucks
I have a 1973 Evenrude 50 hp outboard motor, when i turn the key nothing happens
it is either a wire broke or the the starter solionde is broken check with volt meter at starter + and - if it shows up voltage its the brushes in the starter motor
Jul 13, 2011 | Boating
Water does not come out of the port hole all of the time.
you might just have dirt in the water view port try a real smal drill bit BY HAND to clean the hole . if the morot doesn't run hot then you really don't have a problem
Apr 27, 2010 | Boating
Boating Logo
Top HP Boating Experts
vince
Are you a HP Boating Expert? Answer questions, earn points and help others
