Sync now does not sync my unit - Audio Players & Recorders
Mpc 2050 sc 222
Laser sync detection error (Y): Replace BCU board Laser sync detection error (Y): Replace laser unit Laser sync detection error (Y): Check laser unit connections
May 23, 2015 | Ricoh Aficio Mpc2050 Color Digital...
Unit says waiting to sync but computer says can't find it
If you have not already done so you probably need to download a software piece from the GPS manufacturer in order for the Computer to sync up to the unit. I have a hand held device that requires this as well as a unit for my auto. Go to the unit manufacturers website and look up the unit model - there should be instructions on how to sync.
Jan 22, 2011 | GPS
I am not able to download mp3 I purchased from Amazon from my computer to the mp3 player. What are the steps I need to follow?
If you are using g Windows Vista with Windows Media Player 11 , you will need
to follow these instructions.
Note: You will be able to download purchased/subscribed songs to the unit.
1. Start Windows Media Player 11 and then connect your unit to your computer. If
you have not set up synchronization between your computer and this device, the
Device Setup Wizard starts.
2. In Device Setup - Configure Sync, write a name for your mp3 player.
3. Click Finish. The window closes and the Sync feature is displayed.
4. From the left pane of this Sync feature, you can select from Pictures, Music, and
Video.
5. After selecting a category, select the songs, pictures, or video from the center pane.
6. Drag these songs, pictures, or video into the Sync List, which is the right pane of
the Sync feature.
7. Click the Start Sync button on the Sync List pane.
8. Repeat steps 4-7 for any other items that you want to copy to your unit.
If you are using g Windows XP with Windows Media Player 10 , you will need to
1. Start Windows Media Player 10 and then connect your unit to your computer. If
. In the Device Setup Wizard, select Manual.
3. Click Finish. The wizard closes and the Sync feature in the Player is displayed.
4. Select the Library option. On the left pane select Sync List.
5. From the left pane you can select All Music or My Playlists and you will see the
songs located within these folders in the center pane.
6. Select the songs from the center pane, and drag them to the Sync List.
If you want more info you can download your manual here
http://www.devicemanuals.com/downloadguide.php
May 28, 2010 | GPX ML858B Digital Media Player
Garmin nuvi 660 in PC Sync mode even it is not connected to PC USB or AC power supply. So the GPS is useless since it is not even in navigation mode. Any idea how to solve it?
Here's a work around. 1) Plug the USB cable in and let enter Sync Mode as usual. 2) When the Garmin unit is in Sync mode, unplug the USB cable. 3) The Garmin unit will start to exit Sync mode, at which time, IMMEDIATELY plug the USB cable in again. 4) If you plugged in the USB cable in time, notice the Garmin unit will remain out of the sync mode.
Jul 04, 2009 | Garmin Nuvi 660 GPS Receiver
Hi I would like to add the free songs my MW3836 offers Sherry
If you are using Windows Vista with Windows Media Player 11, you will need to follow these instructions.
1. Start Windows Media Player 11 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
3. Click Finish. The window closes and the Sync feature in the Player is displayed.
4. From the left pane of this Sync feature, you can select from Playlists or Library and you will see the content of these folders in the center pane.
5. Select the songs or entire albums from the center pane.
6. Drag these songs or albums into the Sync List, which is the right pane of the Sync feature.
If you are using Windows XP with Windows Media Player 10, you will need to follow these instructions.
1. Start Windows Media Player 10 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
2. In the Device Setup Wizard, select Manual.
5. From the left pane you can select All Music or My Playlists and you will see the songs located within these folders in the center pane.
Dec 07, 2008 | GPX MW3836 MP3 Player
I cant delete anything or upload
Dec 01, 2008 | GPX MW3836 MP3 Player
I got a gpx MW3836 1gb mp3 player. i cant get any music on there from my wondows media player lists. my playlists songs might have been copy rights protected on it. i want toknow how to get my play lists...
Converting wma's to mp3 costs money unless you are getting the songs from an actual CD. Better to get an mp3-only music service like Limewire, Rhapsody Mp3, etc.
-Tha Mp3 Doctor
Nov 27, 2008 | GPX MW3836 MP3 Player
Making a folder will not work for me??
You cannot just create new folders - the player will not recognize them.
-Tha Mp3 Doctor
Nov 13, 2008 | GPX MW3836 MP3 Player
Miranda
-Tha Mp3 Doctor
Aug 29, 2008 | GPX MW3836 MP3 Player
18 people viewed this question
 Grubhead
Grubhead
