Question about Briggs Garden
Have a Briggs 21hp model 33m777 engine will turn over without plug but when install plus will not spin fast enough to start drags
    Problem Solver:
  • 11 Answers
I am assuming the engine is in a lawn tractor with battery and key start? Have you checked your battery to see if it is fully charged and has the required cranking amps? Have you tried another battery or tried to jump start from a battery booster box?
Posted on May 16, 2017
I have new battery and new starter,engine turns over but stops at a certain point and will not start, oil level and fuel level is good
remove the spark plug and crank it .if it spins real good then put plug back and try it . . last year mine bent an intake push rod .
Aug 22, 2015 | Craftsman 46" 21hp Briggs & Stratton Turn...
Briggs & Stratton 33M777/21HP
Check your valve adjustment first as these uses a decompressor that on the camshaft itself.
Now while checking the valve clearances as you go past TDC of the compression stroke there should a little bump on the intake valve when the decompressor is working. If this bump is not there and the valves are set correctly then the decompressor has failed and requires the cam to be replaced.
10 276781SingleCylinderOHV pdf
May 02, 2015 | Briggs & Stratton Garden
Why is my Briggs and Stratton mower dragging? It won't turn over fast enough to start
If it is an OHV engine the valves are needing adjusting normally as the decompression system quits working causing high compression at start-up speed.
Apr 02, 2015 | Garden
Craftsman 21hp motor 42" cut only turns over 180
adjust the valves on the Briggs engine .004 ~ .006
if it's a Kohler, it might be a lot worse than that...
Sep 09, 2014 | Garden
What is valve gap on 18 hp briggs and stratton
This might have the valve gap:
http://outdoorpowerinfo.com/engine_specs/briggs_valve_gaps.asp
Here is a link for the Briggs website about common small engine issues. I hope it helps at least a little.
4 Common Small Engine Problems How To Fix Them Briggs Blog
Nov 21, 2017 | Garden
Sarter will not turn engine over
Two things cause this...a bad starter or weak battery...not sufficient Amps will not allow enough power to the starter to spin it fast enough to start the engine....a bad starter simply cannot use the power supplied it to turn the engine properly. Have some one do a load test on the battery..tests the battery simulating starting the engine. If ok it is the starter if not replace the battery..good luck.
Apr 09, 2014 | Briggs & Stratton Starter Briggs Stratton...
Why won't my starter turn my engine fast enough on
bypass the battery cables with jumper cables if there bad they will not carry the amps needed to crank it
Apr 23, 2012 | Briggs & Stratton Garden
21hp intek v-twin runs only with choke on full
You are not getting enough fuel.... by choking it you are enriching the mixture with less air , more fuel.Some where in the fuel system or carbureator something is still plugged.Or the mixture screw is too far in.
Oct 30, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
Top Briggs Garden Experts
Mike
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
