Question about Vizio Televison & Video
Vizio E422VLE LCD. Screen goes blank. Still have power/sound/dim picture [flashlight]. Turn off/on to get it to work. Soon after, black screen again. Should I replace power board or backlight strips?
Vizio E422VLE LCD TV / SN LAQKLSAN0501736 / year ~2011
  • 155 Answers
SOURCE: Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Posted on Oct 26, 2008
Bat1956
  • 585 Answers
SOURCE: LCD dim.
If you have replaced the screen and the inverter, about the only thing left is the flexible cable from the monitor to the video card. I take it that the Fn+F8 makes no difference?
Posted on May 23, 2009
TV #1
  • 129 Answers
SOURCE: my 32" lcd vizio vx32L turns on there's sound
Have you tried the T-con board?
Thank you,
Posted on Dec 18, 2010
  • 12 Answers
SOURCE: I have a vizio vz37l tv. When i turn it on the
its the main board...
Posted on Mar 07, 2011
Slinteriors
  • 8617 Answers
SOURCE: Vizio Model SV320SVT powers on, after Vizio splash screen it goes blank. Power stays on, but no backlight on screen.
Yes its very repairable as long as the logo stays white you can assume the main boards good. I would recomend contacting the people at www.tvrepairworld.com by hitting the contact us button from their website. They will be able to assist you in finding out whats happening with the set for free. They have most parts available as well.
Posted on Aug 07, 2012
Oct 26, 2008 | Vizio Televison & Video
Tip
Diagnosing a LCD blank screen problem.
Recently a 3 year old VIzio TV I bought started having problems. The set would turn on normally for a few seconds then the picture would go dark with everything else operating normally including sound. Remembering a similar laptop computer problem I diagnosed previously, I immediately suspected a defective TV screen backlight. To verify this in your own TV, get a very bright flashlight and with the TV operating in the failed blank screen mode, shine the flash light into the blank screen from various angles and distance (including touching the screen). If the LCD is still operating, you'll see a dim motion in the flashlight's reflection, thus proving it is indeed a failed backlight.
on Jan 27, 2015 | Televison & Video
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
No picture
Sounds like you have a backlight problem. To verify this, turn on the set, dim the lights in the room, and shine a bright flashlight on the screen. If you see a faint picture you have a backlight fault. It could be as simple as a bad capacitor in the power supply, or a faulty inverter board, or in rare cases a bad backlamp.
May 04, 2013 | LG 32LD350 32 in. LCD TV
Dp32648 picture goes black, tv stays on with sound.
Dim the lights in the room, turn on the set and shine a bright flashlight on the screen. Do you see a faint picture? If you see a faint picture, you have a backlight fault. Could be several things, you could have a bad backlamp, defective inverter, defective 24vdc power supply, or a faulty main board. I would highly recommend you get a diagnosis
Apr 05, 2013 | Vizio Televison & Video
Black screen with sound
Turn on the set, dim the lights in the room, shine a bright flashlight on the screen. If you see a faint picture, you most likely have a fault in the backlight circuit. Are you wanting to repair this yourself?
Mar 07, 2013 | Vizio VO47L 47 in. LCD TV
When I turned on my vizio vo37om this morning, there was no picyture, screen is black. Sound is fine
Dim the lights in the room, turn on the set. Shine a bright flashlight on the screen, do you see a faint picture?
Feb 11, 2013 | Vizio VO370M LCD TV
Why does my Vizio E470VLE LCD TV have no picture but it does have sound?
you may have a backlight problem. To verify this, dim the lights in the room. Turn on the set and shine a bright flashlight on the screen. If you see a faint picture, you have a backlight fault.
Jan 21, 2013 | Vizio E470VA 47 1080p 120Hz LCD HDTV
Viziov047l sound but no picture
Dim the lights in the room, turn on the set and shine a bright flashlight on the screen. Do you see a faint image on the screen?
Jan 05, 2013 | Vizio 42 in. LCD TV
Televison & Video Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
