Question about GE Kitchen Ranges
How to reset the clock on a GE Medaillon 850 stove
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: GE Stove clock shows FFF and oven will not work
GE Error Code: FFF
Condition: Door motor safety circuit
Fix: Repair Electronic Range Control (ERC)
Usually, failure happens after power surge.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 13, 2009
zcomputerwiz
  • 92 Answers
SOURCE: I have a ge medaillon 850 30
Element is burned out. Get a replacement from GE or a repair/parts shop. They are relatively easy to replace, two wires and four screws or so. Be sure to unplug before you start :)
Posted on Dec 16, 2009
SOURCE: Frigidaire Stove clock resets to 12:00 when igniters turned on
I have the same problem. This is an intermittent problem, maybe once every 20 to 30 starts the clock goes resets and the appliance beeps just like if unplugged it and then plugged it in again. I’m an electrical engineer and this sounds like the microcontroller that runs the appliance is being reset by noise caused by the spark igniters. This is definitely a design problem. Separating the wiring of the igniters and the control board should help. When I get a chance I’ll have to connected an oscilloscope and look at the noise. The control board microcontroller reset pin probably needs an RC snubber or an isolated ground. If /when I find something more definite, I’ll place another posting.
Posted on Jan 18, 2010
GE stove clock #jgb700eej1es
Fixya does not sell replacement stove clocks. Check with a local appliance parts supplier.
Aug 06, 2016 | GE Kitchen Ranges
GE true temp flat top stove/oven isn't working at all, there is power to it, if you turn the burner dial on the clock/electronics turn on but nothing works. turn dial off electronics/clock turn off
sounds like you are missing one leg of the 240V power supply... first thing is to reset the circuit breaker. Then, meter how many volts you are getting at the terminal block where the power cord bolts on... Help Me Find My Model Number RepairClinic com, GE Terminal Block WB02X10606
Jul 26, 2016 | GE Kitchen Ranges
Reset clock and oven light came on flashing
THERE IS A PROBLE WITH THE ERC (CLOCK) NOT TO SURE IF I WOULD USE IT EITHER. THE PART IS EASY TO CHANGE JUST TURN POWER OFF AT THE BREAKER FIRST. YOU CAN FIND THIS PART HERE.
http://www.searspartsdirect.com/partsdirec
Apr 22, 2010 | GE Profile JTP18 Electric Single Oven
I have a ge medaillon 850 30'' range oven and the baking element does not comes red when I turn it on. There is only a small part on the left side of the element about 1 inch long that get red. All the...
Dec 16, 2009 | GE Ovens
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
GE Error Code: FFF
Feb 13, 2009 | GE JSP26 Electric Kitchen Range
Cannot reset clock on my electric stove after a power failure!
Unplug the stove for 10 minutes, then plug it back in.
This should resolve your problem...
Nov 20, 2008 | General Electric Stove/Oven/Range Chrome...
GE Kitchen Range
have you tried clock then setting it
Feb 16, 2008 | Kitchen Ranges
The touch pad panel on stove is blank
on the ge range, you need an ERC its the main control for the oven. yes its costly. comes in a kit with a new wire harness
Nov 16, 2007 | GE Profile JGSP48 Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
