Question about Garden
Oil and gasoline specs - Garden
Can we use 15W-40 motor oil,for my 2004 Kia Sorento diesel.
You use what the owners manual says
I would suspect if it were 15W-30 or 40,
it would be diesel rated oil, not gasoline motor
oil as your asking
Can always check with a dealer or google it
You need the specs for the oil for a diesel
Sep 01, 2013 | 2005 Kia Sorento
What type of gas to use in a craftsman edger 358.773110
FUELING ENGINE This engine is certified to operate on unleaded gasoline. Before operation, gasoline must be mixed with a good quality 2-cycle air*cooled engine oil. We recommend Craftsman brand oil. Mix gasoline and oil at a ratio of 40:1 (A 40:1 ratio is obtained by mixing 3.2 ounces of oil with 1 gallon of unleaded gasoline). DO NOT use automotive oil or boat oil. These oils will cause engine damage. When mixing fuel, follow instructions printed on container. Once oil is added to gasoline, shake container momentarily to assure that the fuel is thoroughly mixed. Always read and follow the safety rules relating to fuel before fueling your unit.
Sep 12, 2011 | Craftsman Garden
How much oil would i ad to a pint of gas at a 50 to1 ratio
A pint is 16 ounces, add 1/3 ounce of oil for a 48:1 mixture.
Gary
Aug 30, 2011 | Vacuums
What type of oil
Use SAE 5W-30 motor oil certified for gasoline engines by the American
Petroleum Institute (API)
Mar 08, 2011 | 1999 Ford Econoline
I want to check audi r8 all the oil spec, how??
The engine oil specifications for Audi R8 4.2 FSI V8
- Quantity: 14.2 liter
- Type: Castrol Edge 5W-30
- Oil change intervals: Max. 12 Months / Max. 15000 km
Castrol have developed EDGE 5W-30 in co-operation with the VW Group. This oil sets new standards in the industry in regards to cleanliness of the engine, thereby reducing harmful emissions and subsequent damage to the environment.
The technology in this oil also reduces long term blocking thereby prolonging the life of the diesel particulate filter.
Castrol EDGE 5W-30 is equally suitable for gasoline and diesel vehicles where performance specifications VW 504 00 and 507 00 are demanded.
In addition to its cleaning properties, EDGE 5W-30 antiwear technology provides strong protection for modern FSI, TDI and turbocharged engines.
EDGE 5W-30 is also approved for use in modern BMW and Mercedes gasoline and diesel engines including those equipped with a DPF that require BMW Longlife -04 or MB-Approval 229.51.
www.castrol.com
Nov 23, 2010 | 2009 Audi R8
Need torque specs for oil pan
here is website for kohler
http://www.kohlerplus.com/main_frame.asp
select command pro twin
then select tp2428c service manual
it has all the details you need
cheers hope it helps
paul
Aug 05, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
What is the oil weight for this car?
You don't say if you have a gasoline or diesel engine. For the diesel I would recommend Shell Rotella 15W-40 oil. For gasoline engines I would recommend a 10W-30 or thicker. (The larger the number the higher the viscosity.) If you have high mileage you might want to use a 20W-50 oil, but in colder climates you may want more like a 5W-30. Sometimes the oil cap has the spec printed on it.
Dec 19, 2009 | 1986 Volkswagen Jetta
What is the gas and oil spec for Homelite Edge/Treamer and were can I find the online manual - UT20930
50:1 mixture. Trimlite, Trim 'n Edge, and EasyReach models.
Pre-mix unleaded gasoline and 2-cycle engine oil in a clean 1 gallon container approved for gasoline.
Unleaded gasoline. Mix Homelite Premium Exact Mix oil with gasoline according to the instructions on the package. If Premium Exact Mix oil is not available, use a high quality 2-cycle engine oil, mixed at 2.6 oz. per gallon (US). Do not use automotive oil or 2-cycle outboard oil.
Homelite manuals are quite hard to find. I'm sorry that I can't help you with that.
Oct 11, 2009 | Homelite Garden
What engine oil do I need for a gasoline Tiller CT2067 - 6.5HP
Find what type engine, go to that engine site, they should have specs.
Mar 27, 2009 | Garden
Looking for relacement engine-running
Current engine taken to small engine repair facility for F & R seal and oil pan gasket replacement
Dec 25, 2008 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
