Question about GE Microwave Ovens
How do I reset the clock on my GE Madaillon 850 Oven?
Reset clock on over the range microwave
Go to this link....you can download the users manual. The procedures for setting the clock are on page 22 of 68.
JVM1950SR1SS GE MICROWAVE Manual
Nov 02, 2014 | GE SpaceMaker Microwave Ovens
GE Profile Advantium 120 oven: Clock is on and stuck, unit will not work otherwise.
Unplug the microwave oven for 60 seconds to reset microprocessor, hopefully this will cure the problem.
Jul 05, 2012 | GE Profile Advantium 120 Wall Oven
I have a GE sensor microwave oven. Tried to heat food and sensor eror came on. Everything is running even the timer but no sound but the timer is running. Cant this be reset pls help
HELLO.
This is the solution to reset your microwave.
1 Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
1. Set the clock by pressing the "Clock" button.
2. Turning the dial on the GE sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
3. Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the GE sensor microwave oven.
4. When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
5. Press the "Start" button to allow the clock to begin on the GE sensor microwave oven.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Hi, my problem is with my GE advantium speedcook microwave oven. When using 'speedcook' feature, the oven starts, then there is sparking inside the circuit board area, followed by a loud POP, and this...
  • Select the "Options" menu and adjust the clock display settings if the display is blank. Set the clock if the oven won't start. The clock must be set for the oven to work properly, as oven programming is dependent on the clock.
  • Close the door tightly if the oven won't start. The oven won't start if the door isn't closed. You can identify from the lights whether the oven failing to start is related to the door or to the power supply. If the control panel is illuminated and interior lights are on when you open the oven door, you can be sure the oven is receiving power and any starting problems are due to the door not being closed tightly.
  • Press and hold the "Clear/Off" button if the oven performs strangely. Be sure to hold it for a few seconds. This will reset the GE Advantium.
    But as you mentioned that there is /was a loud noise this is a indication of the unit make any usual noise (groaning, gurgling, etc.?) or was / is it either louder or quieter than normal?It may be as simple as the top door switch or its mount or it may be a bad magnetron or shorted diode.
    For manual of the oven.please click the link below:--
  • http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40577-1.pdf
  • Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
  • Aug 12, 2010 | GE Advantium 120 Convection/Microwave Oven
    Clock Losing Its Memory
    Our oven clock does the same thing every time the power blips, but we live way out in the boonies and expect occasional problems. Do your lights blink too? Check with your neighbors to see if they have power problems. If this is a chronic situation, contact your power company to see if they can repair the situation.
    Sep 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    HOW DO I RESET MY GE JE1549GW MICROWAVE
    Terry I am assumming that you are referring to resetting the clock. If so, push the clock button then set the time then push the clock button a second time and you should be all set.
    Feb 08, 2009 | GE JE1540 Microwave Oven
    How do I set the clock on a GE Spacemaker microwave oven?
    You can get the manual here.
    http://www.retrevo.com/s/GE-JVM1640SJ-Microwaves-review-manual/id/1080ci954/t/1-2/
    But usually you just press the clock button to set
    Good Luck and Please Rate Fixya!
    Jan 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    I have a GE profile advantium oven. The oven seems to operate, however the green display is blank with a dash in the upper left corner. Cannot set clock or get any written information from the green...
    The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
    Let us know if the hard reset doesn't fix it.
    Jul 10, 2008 | GE Microwave Ovens
    WHEN PRESSING COOK TIME OVEN CLICKS ON FOR ONE SECOND AND RESETS CLOCK
    Please try on some other power point as if there is loose contact or sparking in point which cause to switch off as soon as you start because of heavy current drawn by oven and clock also resets. If not solved even then must have some short circuit or over loading in timer circuit or magnetron. in this case you have to call for a service engineer.
    Jul 26, 2007 | GE JVM1860 Microwave Oven
    Microwave Ovens Logo
    23 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    vince
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
