How do i recover my firestick tv pin number - Televison & Video
Do I need a firestick if I have a smart tv?
Some of the programming you get with a firestick is in Hi def and not readily installed on any smart TV. It depends on what programs you want to watch. If you have loaded up your TV with a lot of programs, you can use the additional memory in the firestick to expand the number of programs you can load into it as well.
Apr 06, 2018 | Televison & Video
How to build a library in Kodi 17.6 using a Firestick and remote, no keyboard.
Firestick allows installation of Kodi and you can easily setup kodi on Android devices which also includes firestick How to Install Kodi on Fire TV Firestick Easy Guide
Once that is done, feel free to setup 101 Best Kodi Krypton Addons for March 2018 Working List which will let you stream movies, tv shows, sports, cartoons and a lot more of stuff.
Feb 08, 2018 | Televison & Video
How to connect firestick to vizio smart tv e50x
Plug the fire TV stick into a HDMI port on the TV. Plug in power for firestick. Change the INPUT to that HDMI port Main firestick screen should appear after 10-20 seconds
Dec 31, 2017 | Vizio Televison & Video
Brought a second hand Firestick it's asking for a PIN number which I don't have how can I reset the firestick
hi Jeff.
this is all i could find out so not sure if it will help you.
Steps To Reset Your Fire TV or Fire TV Stick
  1. On your Fire TV device, click Settings.
  2. Scroll over to the right and click System.
  3. Scroll down and click Reset to Factory Defaults.
  4. A dialog will appear that reads "You are about to reset your Fire TV to its original factory settings.
  5. or go to this link and read up some more.
how do you reset the firestick Google Search
or this one.
https://www.amazon.co.uk/gp/help/customer/display.html?nodeId=201422940
Dec 12, 2017 | Televison & Video
How do i get the firestick on my tv screen..set on hdm1 or hdm2 or ? I don't know how to bring it up on the screen?
The TV remote has a button for that. Input Select or Source or SEL. However simply turning off anything except the firestick should make it work. I presume the firestick came with a remote. Simply turning it off and on from that should do it. Make sure you can see the firestick when you press the buttons.
Oct 21, 2017 | Televison & Video
Can you explain in simple terms that if I buy a fire stick with kodi, does that means it automatically streams various films and music from Amazon or Netflix foc. Does it needs to be jail broken
Why would you buy kodi installed FireStick when you can do it yourself in a few minutes? I mean, OK, you don't have any problem to spend some additional money in buying Kodi preinstalled Fire Stick but what if you get problems later? It is always better to know how to install Kodi on Firestick as it will help you in future too. How to Install Kodi on FireStick
Jul 03, 2017 | Televison & Video
There is no signal on my tv from my firestick
Make sure your firestick is plugged into an outlet. Make sure you change the input settings on your TV to access the firestick output.
May 06, 2017 | Televison & Video
I downloaded kodi on my FireStick but it won't install it, how can i fix it
Hey, there are couple of ways to download as well as installing Kodi on Firestick. I am not sure which method you used to download Kodi. I would suggest you download Kodi using ES File Explorer and then it will show install button as soon as download completes.
You can also check this guide - https://www.firesticktricks.com/install-kodi-on-fire-stick.html
If any further issues, please let me know.
Mar 06, 2017 | Televison & Video
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
