Question about LG enV3 VX9200 Cell Phone
Speakers won't turn on and won't make sound
Speakers aren't working
The kenwood KDC-MP333 in my truck is connected to a set of kenwood speakers. But when I turn it on they won't work the stereo still shows the display but when I turn the stereo on it makes a sort of...
Disconnect the speakers and try it with another speaker or speakers not in the truck. If it works, the speakers or the wires to them are messed up. If it doesn't you probably damaged the output capacitor in the radio by turning it on without speakers attached. Realize that the speakers are part of the radio circuit and act as resistance. Without them, there is no resistance and it puts a strain on the radio.
Jan 02, 2013 | Car Audio & Video
Altec lansing ATP4 speakers aren't working
is it possible that you may have plugged the speakers into the microphone or audio input jack on the computer instead of the speaker/headphone/audio output jack?
Apr 28, 2017 | Altec Lansing Audio Players & Recorders
On 2001 Crown Vic, radio lights are on, channels change,etc but no audio. Fuse issue or any other possibilities?
sounds like your speakers aren't connected properly. check your speaker leads coming from your radio and make sure they are positive to positive and negative to negative. if you're using an external amplifier,check your RCA cables and your speaker outputs on the amp. make sure thr remote turn on lead is connected, otherwise the amp won't even power on.
hope that helped, good luck
May 31, 2012 | 2001 Ford Crown Victoria
There is no sound in my pc
Some possiblities are:
* The sound is muted or turned down to zero. (This can often be controlled from the keyboard; for Windows 7, try the control panel > sound > adjust system volume).
* Speakers aren't connected, are turned off or are set to zero volume.
* Speakers are broken (least likely).
May 09, 2012 | Dell Latitude D610 Notebook
If all speakers except some of the super tweeters in my gem sound tr-150 cabinet aren't working, could it be the crossover network that they appear to be all wired to, is no good, or do you think all...
Did you actually mean "all speakers... AREN'T working" except some tweeters? Crossovers don't protect the woofers. If crossover die all speakers they protect go silent due to loss of signal. Excess volume or distortion kills speakers and not always linearly.
If you said it wrong and some tweeters work, I'd suspect the latter above...
You (or we) could guess or you could take out one tweeter at a time and swap it with a (presumed) working one or just emasure it for dead short or open with an ohmmeter. If the tweeters check out and work elsewhere the problem would likely be within the cabinet.
Sep 08, 2011 | Gem Sound TR-150 Speaker
Both speakers on my lg chocolate has stopped working. i can go to my sounds and select play but no sound comes out. during a call i can hear nothing even when i switch it to speaker mode. but when it rings...
I assume you have tried turning the volume up during a call? if so and the volume is all the way up and nothing is coming out, try plugging headphones in to check that there is sound that way. If there is, remove the headphones and that may fix the problem itself as phones can get confused "thinking" there are headphones in when there aren't.
Aug 26, 2011 | Cell Phones
Good morning -- I am having an issue with my volume - I have it on the highest possible, but my speakers aren't able to pick up much still
Does any sound at all come out of your speakers?
1. Go to Start > Control Panel > Sounds and Audio Devices
2. Under the volume tab, turn your "Device Volume" bar up
3. Also, click on "Speaker Volume" at the bottom and adjust both left and right speaker bars up
Jul 20, 2011 | HP Compaq Presario SR1920NX PC Desktop
I hooked up the boston speakers 4 plus wolfer and when I play music on You Tube, the rear speakers don't play. They work in the sound "test." They also work when I set the speakers...
the sound on utube is only stereophonic, hence you will get only stereo putput. If you play anything recorded as quadraphonic or above all your speakers will give sound output.
Jun 22, 2011 | Boston Acoustics MicroMedia Computer...
Our rear speakers aren't working properly.
Well that proves the hardware works. Crack the manual for the unspecified model and see why the source selected or the sound mode selected don't utilize those speakers.
May 30, 2011 | LG Audio Players & Recorders
LG enV3 VX9200 Cell Phone Logo
328 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
