Question about Building Materials
After a power failure the wall panel only opens the door and not the remotes how do i fix it?
My digi door II opens before a powerfailure with a remote but after the powerfailure it only opens on the wall panel thats opens and closes the roll-up door. How do i fix that?
SOURCE: BMW remote control problem
I have a e60 525i that I just brought and it has the same problem, the owners manual suggests driving with the key in the ignition for a long time as the batteries are rechargable and may have gone flat, i have tried this and it doesnt seem to work
i also read something about getting water in the aerial about the rear window and that wrecks the receiever. My car isn;t under warranty so not looking forwarding to taking it to bmw
Posted on Jun 27, 2008
jyackle5
  • 8197 Answers
SOURCE: Garage Door Wont Close Craftsman 1/2 HP (1998)
What it is is the electric beams at the door are getting blinded buy the sun or out of line. They are the two black boxes on both sides of the door about a foot from the ground. Put a piece of card board in front of them not blocking the beam dut to block the sun. All that they are is safety beams for kids so they do not get hurt. If you have to move them to the top where the sun will not hit them. Sorry to say though you can not remove them all the way. Also make sure the lite on them is not blinking if so they are out of line.
Good Luck and Please Rate FixYa!
Posted on Mar 05, 2009
  • 3197 Answers
SOURCE: Garage door opener remote won't work
meerkat1 your receiver has quit working which is part of the logic board. The logic board runs around $80.00 for the part alone. Might be time to get a new opener.
Posted on May 12, 2009
swolfinor
  • 504 Answers
SOURCE: Grage door blinking yellow, click and won't open with anything.
TRY RESETTING THE UNIT BY UNPLUGGING IT FOR ABOUT 5 MIN.
IF WHEN YOU PLUG IT IN THE REMOTES STILL DON'T WORK TRY TO REPROGRAM THEM.
IF STILL HAVING TROUBLE--
COUNT THE FLASHES - GOTO LIFTMASTER.COM DOWNLOAD A FREE PDF FOR A SIMILAR UNIT (THE MODEL NUMBERS ARE DIFFERENT BUT THE CODES ARE THE SAME).
HOPE THIS HELPS
Posted on May 27, 2010
swolfinor
  • 504 Answers
SOURCE: remote only closes the garage door, will not open it
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
In your case the expansion of the wall in the afternoon may be enough to cause pressure on the wire to increase the problem – works in the morning but not the afternoon.
Also after you change the batteries you need to reprogram the remotes.
HOPE THIS HELPS
Posted on May 30, 2010
How do you programme remote control to digi garage door motor ii
This youtube video may help you. Google docs is free, you can download the manual here: https://docs.google.com/document/d/1xfJFOC1aMNmSsDHtICYyC9bf1-z1oJiriAGHH6VjGBM/edit
Nov 16, 2016 | Building Materials
How can i open my craftsman 315 garage door opener with a broken remote?
you might have a power failure. can you still use the wall unit?
Mar 26, 2013 | Craftsman Building Materials
Door opens by itself
Will likely need a little more info. I am presuming this is the wireless version since it's a Digi Code. However, my first thought is that the problem is not necessarily with the keypad. Most likely could be a programming issue. Have you tried to clear the memory on the Logic board on the Garage door opener and then re-program all of the openers, including the keypad?
Some Logic boards have a dedicated slot for one wireless Keypad that is made specifically for that brand of opener.
A helpful hint: When programming the keypad, have another person help you. Have them push the program button according to the programming instructions for your GDO Make.(Garage Door Opener)
Then you key in the required sequence for programming your keypad immediately after the programming button has been pressed. This reduces the amount of time the logic board wireless memory is in the learn state.
Sometimes stray radio transmissions operating at or near your openers frequency can inadvertantly be programmed into your openers logic board. Especially if there are other same manufacturers GDO units wireless remote transmitters in use within close proximity operating on the same frequency.
Another possible cause is in your hard-wired wall control button or wiring to it. There could be a short in the contacts causing the opener to operate, or a short in the wire to the wall control button. I've run into smashed wires that have had the outer insulation pierced and the metal staple shorts across both wires. (this is not good for the logic board, as it can damage sensitive circuitry on it. Causing more Costly repairs)
One way to isolate the issue is note when this occurs. Is it always the same time every day? Or is it completely random?
I hope these possible solutions help MASTER_TECH1
May 27, 2011 | Digi-Code Digi Code 5202 Garage Door...
How do i programme a digi key remote to my digidoor II garage motor, my original fell and no i bought new digi key remote. plz help
How to program a digi-key remote control :
- on the wall console press the light toggle button to switch the light off.
- press and hold the light toggle button, the light will come on and after 5 seconds go off.
- release the button and the light will go on again.
- within 30 seconds press the required key on the digi-e key transmitter (your remote control). The light on the digidoor ac/dc will go off.
- to confirm press again the same button the transmitter (remote), the light on the digidoor ac/dc will flash foor times. Done
Apr 22, 2011 | Audio Players & Recorders
Hi, My Digidoor II opener only moves the door 20mm at a time and stops. The same happens using the remote or the wall mounted pushbutton. How do I fix this?
I had the same problem easy to fix!
It's the rocker rail (small plastic thing that ajusts the power and direction) that is damaged. Buy the part for R36-00 from any Digidoor agent 011 3978448.
Remove the motor from the installation rail and open the blue motor cover. You will see the rocker rail is attached to the blue cover, one of them will be broken. Replace both of them (up and down)!
Jan 06, 2011 | Computers & Internet
While trying to reset the outside panel the remotes wont work and the door wont go down or up with the wall unit or remote. I have tried reset but its doesent work. What else can I do?
Make sure the opener is still plugged into the outlet and that the breaker hasn't popped. If you held the smart/learn button in for 6 seconds it would erase the memory and the remotes would not work but the wall button should. Sounds like no power to the opener.
Aug 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation.
The test is to disconnect the push button wires at the power unit. If the interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Apr 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens on it own and light blinks
  • Stuck remote control button. Check all remotes. check LED on receiver.
  • Staples around Multi-Function Control Panel bell wire could be cutting into that wire. Remove wires from opener and test. Replace staples causing intermittent short.
  • Multi-Function Control Panel could have sticking door control push bar. Remove wires from control panel and test. Replace control panel if defective.
Dec 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
REMOTE CONTROLS WILL NOT WORK-WALL BUTTON FLASHING RAPIDLY
Does your wall switch have a lock feature? By pressing the lock button, the remote control is disabled. A flashing light indicates this feature has been activated.
To deactivate, press and hold the lock button for 2 seconds. The flashing should stop and your remote should work again.
Dec 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
