Question about Sharp Televison & Video
Sharp aquos 60 inch screen delamination - Sharp Televison & Video
SOURCE: Sharp Aquos LC 37HV4U - problems with AVC
I have a fully functioning lc37hv4u box & cable that I will sell for 200$ my lcd got cracked. let me know psxpirate25@hotmail.com
Posted on Aug 01, 2008
1Guru
  • 61 Answers
SOURCE: Cracked LCD Screen on Sharp Aquos LC37D43U 37-Inch 720p LCD HDTV
Most LCD's just went down in price by around 2-400 dollars. I would suggest buying a new one. The cracked screen might mean that the liquid will ooze out and get worse and worse as it ages. However, it may only have a crack and not get any worse than it is now. If you can live with it and it doesn't get worse, you can view it that way for another 10 years and be fine.
The fact that the LCDs are cheaper now and you only have a 37 inch, you might consider getting a larger one that you have had your eye on for a long time. (Note: even though I am a firm believer in LCD's over Plasma, plasmas are a few hundered dollars cheaper and if you know your children are prone to breaking things... it might be the way to go.)
Replacing the screen is possible, but more costly than the new T.V.
Posted on Dec 12, 2008
cheater21
SOURCE: Sharp Aquos 37" picture
Those lines are because of "Interlacing". a REALLY bad case of it. what are you watching when this happens?
Posted on Jan 02, 2009
  • 1779 Answers
SOURCE: Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Posted on Feb 28, 2009
SOURCE: SHARP AQUOS 32 INCH FLAT SCREEN
I had this problem as well guys. Just found a fix thought i'd share.
I simply went into menu>setup>reset . This will perform a factory reset, and you shouldn't have that K or the volume problem anymore.
I tried all the fixes involving volume- input- nothing worked. I tried volume- ch- but that K never changed colours.
It all came down to a simple menu option reset.
Posted on Aug 21, 2009
Red bleeding on 60 inch aquos,
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Jan 28, 2016 | Sharp 60-inch LCD TV - LC-60E69U Aquos...
Can a cracked screen on 60 inch Aquos Sharp TV be repaired?
If it is under warranty then it is cost effective for you. If it is beyond warranty and you did not purchase an extended warranty then the cost of repair would be equal the cost of a new set.
Feb 21, 2015 | Sharp Televison & Video
32 inch Sharp Aquos Screen is cracked. Can it be
Yes, however, the Display is as much as a new set.
Oct 14, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
Apr 26, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Line down the middle of my sharp aquos 42 inch
first make sure it does not come from the signal. If its really from the tv and look like a darker line it can come from the lcd control unit but most of the time its a dfective lcd panel
Mar 22, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
56 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
