Question about Sony Televison & Video
No video, only audio on Sony LCD tv
Googled the problem and tried replacing the T-Con board, but still no video, only audio. Any other suggestions for parts/fixes? Or should I just give in and buy a new television?
  • 718 Answers
SOURCE: Is the T-Con board the LCD controller? What is
Website shopjimmy.com has Sony LCD Controller 400WSC4LV0.4 for the KDL-40S2000. Other sites may also have it.
Posted on Mar 06, 2009
  • 1779 Answers
SOURCE: Complicated Question about repairing circuit board
As long as it's the same model, you can. You will be replacing the entire LCD display. Be very careful in doing so.
Posted on Apr 29, 2009
SOURCE: Sony Bravia television hdmi stopped working
Installing a new software update will this issue. All you need is a compatible USB flash drive. Go to support on Sony.com. Look up your tv model and if there is an update, just follow the instructions to install it yourself. I have a KDL-46S5100 and this worked great. The download and instructions page I used was : http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4769#install
Posted on Oct 10, 2009
welcomejee
  • 10594 Answers
SOURCE: Sudden loss of picture and sound on 40
I do not think T-Con can shut down TV, all it can do to blank the screen, I mean stop picture data towards LCD panel.
Sony would not give T-Con separately as its counted part of LCD Panel but its available in some part shops.
Let me know model number of TV and what boards you have been replaced in TV.
Are these power supply and main boards.
Thanks.
Posted on Nov 11, 2009
Testimonial: "Thanks so much for the speedy response. I don't know which 2 boards they replaced, but will find out. Thanks again "
  • 380 Answers
SOURCE: trying to replace t-con board on a 47lg50 lcd tv,
As soon as you take the back off the set, the t-con board is located at the top middle of the set under some shielding.
Posted on Dec 08, 2009
Sony LCD coulor TV modelklv32nx500,soundok,backlight OK,nopicture
It could be a defective T-CON board, defective main board, or a defective display panel.
I will try a new T-CON board first, then the main board. The display panel is to expensive to replace.
Oct 31, 2017 | Sony Televison & Video
How to change samsung tv t con board
Ken, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung LED TV Repair Con Board Replacement No Picture on Screen Image...
LCD TV Repair
Troubleshooting Distorted Video Con of LCD Panel TV Repair Vizio Sony...
Mar 22, 2016 | Samsung UN65F6300AFXZA - UN65F6300AF 65...
I started having vertical lines on my screen whick first it was only around the upper corner edge
I would suggest that you check ribbon connections between t-con and LCD panel. Also I would have you power supply checked. Unclean sources from the power supply can cause all kinds of strange video problems. If the power supply checks out fine, and the t-con/LCD panel ribbon connections are ok, I would suspect a faulty LCD panel. You can try replacing the t-con, they should be cheap enough to take the gamble. But if you don't want to gamble, get a diagnoses done on the set.
Nov 23, 2012 | Sony BRAVIA KDL-52XBR6 LCD TV
I have a Sony KDL 52w4100 LCD tv. When I turn the TV on, all i get is a blank screen, and no sound.
Tad G chances are you installed the wrong Tconn as that model used two T con boards both look identical but they are not interchangeable the two types were part numbers 185724011 and 185713211 I can assist with determining which version you have
Jan 11, 2012 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My 52ince LCD Sony Bravia TV is started showing 2 vertical lines on each side, but they go away 20 minutes after starting TV. What is wrong?
The tv board call the T-CON decoders board have problems,that why colors vertical lines are showing up in the tv LCD screen panel.The T-CON decoders board,this board sit wright at middle bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Oct 29, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Lines vertically on lcd sony tv
2 possibilities for that kind of problem,
LCD panel is defective or T-Con board is bad.
Please replace T-Con board in TV and if problem still exist, LCD panel is bad.
It is qualified TV tech job to replace board in TV so call local TV tech.
Thanks.
Nov 02, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Televison & Video Logo
20 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
