Question about Hardware & Accessories
My melnor automation 1 outlet water timer 3015 will not turn off while using the manual setting. i followed the "valve opened during shipment" instructions. still doesn't turn off.
Bajanguru
  • 7752 Answers
SOURCE: How to set up greeting w/o automated instructions & options
not possible that is a built-in feature on the phone
Posted on Dec 26, 2008
manhandy
  • 146 Answers
SOURCE: Can't correct the current time in the Melnor 6
go to there web Site
Posted on Jul 13, 2009
SOURCE: No instruction manual came with
What product do you have?
It sounds like an outdoor yard stake with receptacles, where the bottom one-or-two receptacles are always on, and the upper receptacles are controlled by timer.
If your timer is digital, we need to know the exact brand and model number in order to dig out the instructions for you.
If you have a dial-type timer, then you usually set current time by rotating dial. And you set on-off times by moving segments or pins back and forth or up and down. This action depends on the model of timer you have.
Answer back with more information and it is possible we can help you.
Posted on Oct 25, 2010
  • 5089 Answers
SOURCE: need instructions to set time for 8 outlet power Strip timer Utilitech
Copy following link to identify power strip timer:
http://waterheatertimer.org/GE-timers-and-manuals.html#striptimer
Zilla, Utilitec, GE strip timers use basically the same format for programming.
For each ON time, there has to be a corresponding OFF time, and days for On and Off times cannot conflict.
Best guess: you have a conflict or incomplete on-off program.
With Zilla timer, there is added level of complexity since the ON-OFFs are set for different day and night outlets.
Add a comment with the exact timer model number so expert can read the manual alongside you.
Posted on Sep 01, 2012
  • 5089 Answers
SOURCE: need instruction manual for orbit sprinkler timer model 57196
Copy following link for Orbit Sprinkler timer manuals
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=01&Type=Timers
Copy following link for various brand name sprinkler timer manuals, including Nelson, Melnor etc if you need new timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Posted on Sep 11, 2012
Melnor Aquatimer leak
The seal inside the timer is defective.
Jul 06, 2017 | Refrigerators
I have a Melnor 3015 aqua timer (2007 model) that leaks. I am fairly certain it is the connection between the solenoid and the valve but I cannot figure out how to open the thing without breaking the
It's made that way. The case is not meant to be opened, it's a sonic weld (melts the plastic together). It's meant to be a disposable device; it breaks throw it away and buy a new one. Also known as planned obsolesce.
Jan 24, 2015 | Melnor 3015 6 Zone AquaTimer
Melnor 4 zone aqua timer dosent follow program
Water timers and Melnor timers last a year or two. They come with 1 year warranty for defects in workmanship.
Change batteries, reset timer if there is a reset protocol, buy another timer. Melnor, Orbit, are major brands. Gardena is not supported. Yardworks repackages other brands.
Copy following link for all watering and irrigation timers on market, with links to manuals for each brand:
Add a comment and say what you find.
Jun 20, 2013 | Aqua Hardware & Accessories
Melnor water timer
Melnor is major water timer company, and not off-brand. However, water timers last a couple years, or less, sometimes they last long time but that is not often.
If not drained completely of water, they will break when water freezes.
Copy following link to identify all water timers on market today:
Most timers have 1 year limited warranty for defects in workmanship.
Jun 05, 2013 | Hardware & Accessories
Timer 3018AR manual
Timer could be Melnor 3015 or Melnor 3018
Copy following links to download possible manuals:
http://waterheatertimer.org/pdf/melnor-aqua-timer-3015-B.pdf
http://waterheatertimer.org/pdf/melnor-aqua-timer-3015.pdf
http://waterheatertimer.org/pdf/Melnor-3018.pdf
Jun 05, 2012 | Hardware & Accessories
Not a gardenia timer. It is a verve digital water timer (B&Q). There were no instructions in the box.
Verve water timers might be Melnor:
Open following link for manuals.
http://www.melnor.com/instructions.php
Links to other water timer manufactures and manuals are found on following link:
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
Aug 11, 2011 | GARDENA Water Timer
Verve Digital Water Timer as sold at B&Q have lost the operating instructions.
Jun 14, 2011 | GARDENA Water Timer
Lost directions to set timer Melnor 604 F
Melnor 604F Instructions (from Label on unit)All indicator light flashing - replace 9V battery inside unit
1. To Start - turn dial to Off and press Enter.
2. Set Time - set current time and press Enter (Yellow ring).
3. Set Start Time - Set time to start first irrigation cycle (Yellow ring) and press Enter.
4. Frequency - Set frequency of irrigation cycle; e.g., twice a day set 12 h. (red sector ring) and press Enter
5. Duration - Set duration of cycle (Green band) minutes and press Enter.
To change duration - turn dial to new duration and press enter.
To turn water on manually - Turn dial to ON position, water will turn off in 30 min.
Do not press enter in the OFF position as the unit will clear program. You will have to reprogram unit
via steps 2-5 above.
Jan 31, 2010 | GARDENA Melnor/Gardena 101 Flowmeter Water...
Hardware & Accessories Logo
37 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
