Question about Nortel Lands Phones
Nortel 2250 - failure code 8CH. What does this mean?
Norstar m7130
Not to be too obvious, but did you mean Feature*98?
Even then, it should be F*981, or another in that group:
Voicemail Feature Codes Norstar Meridian and Nortel BCM Help Guides
Jun 22, 2014 | Nortel Lands Phones
Remove do not disturb
You need to enter the "Make Set Busy Deactivate Flexible Feature Code" - the "Flexible" part meaning the system administrator can change it, so you'll have to ask. The default appears to be #62.
Jun 20, 2014 | Nortel Lands Phones
All 3 phone sets have no dial tone and arrows to each of the 8 lines are flashing. The caller ID window is blank - no info. The telephone line is working as I am receiving faxes - help?
This usually means the PBX unit is booting up.
Try power cycling the PBX unit. If that does not work, there is some hardware failure on the PBX.
Feb 28, 2011 | Nortel Meridian M7208 Corded Phone
HOZELOCK TIMER CODE NO:2250 NO INSTRUCTIONS
Download instruction leaflets from http://www.hozelock.com/instruction-leaflets.html
Jul 13, 2010 | Garden
F 981
If none of your voicemail feature codes(f980-f989) are active, then that means that the system doesn't recognize any nortel voicemail on the system.Which means that a) your system has a non-nortel voicemail system attached to it, b) theres no voicemail attached to the system at all or c) the voicemail is no longer functioning.
Jun 23, 2010 | NorStar Meridian M7310 Phone
Nortel IP soft phone 2050 shows the licensing failure
hello,
you can downgrade to an earlier version that doesn't require a liscense. you probably know that.Try upgrading to the latest (3.02.0045) version.
Hope this will help
Sep 22, 2009 | Nortel i2050
Sony xplod cdx-2250 in need of code
you need to contact sony at their website and request the code. make sure u have ur serial number handy
Aug 31, 2009 | Car Audio & Video
MP145 Scanning Problem
hi Fulminater.
this is all i could find out from the internet.
Scanner driver will be closed : Code 2250.
Take it to a Canon Repair company, It has a 1 year warranty and needs to be replaced or call 1-800-ok canon.
check can't work the scanner because the cartridge are not inserted.
this is all i could find out.
Nov 29, 2017 | Canon PIXMA MP150 All-In-One InkJet...
Lands Phones Logo
Top Nortel Lands Phones Experts
David Burbee
David Burbee
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
