Question about Franklin Pool & Spa
Franklin motor model 1111630700 wiring info. Looking for 115 volt wire for plug-in
SOURCE: Free wiring diagram for 1978 Mercury Outboard 115 HP boat motor
I have a maintainance manual for this engine (I have the same one) with pages of wiring diagrams. What specific system/area are you interested in, I could scan in the page(s) and email them to you.
Mark
Posted on Sep 20, 2009
  • 497 Answers
SOURCE: need help wiring reverisable 115 volt motor
the only way to reverse the movement it to rotate the stator.
Posted on Oct 06, 2009
buffalonyman
  • 1865 Answers
SOURCE: need wiring diagram for a ge triclad motor
Not all motors are dual voltage, the motor must state on th ename plate that it is dual voltage and can operate on 115
Posted on Oct 23, 2009
SOURCE: I have a Multicontrol 115 volt transformer (4
I went to a train dealer.
Posted on Nov 21, 2009
MOTORWIZJ
  • 1338 Answers
SOURCE: i'd like to know how to change a 115/230 volt pool...
IF YOU SEE ON THE LABEL ON THE MOTOR HOW TO CHANGE FROM HI - LO VOLTS . THATS ALL YA GOT TO DO ..THE WIRES HOOK UP NORMALY
Posted on May 29, 2010
I have a 1/2 horsepower electric motor 230 volt 3 speed w/ capacitor HVAC fan assembly. how do I wire it to power by color coded wires?
Keeping in mind that some motors may be different
The most common wire colors on a 3 speed motor are as follows:
Red- Low speed
Blue- Medium speed
Black- High speed
Brown capacitor wires ( usually two of them connect to the two capacitor terminals doesn't matter which wire to which terminal)
White - Neutral wire on 115 volt systems or the other 115 volt side of a 230 volt system ( note on a 230 volt motor this wire may not be white). Remember this is the most common wiring but different motors may have different wiring.
Hope this helps.
Bob
Nov 30, 2014 | Heating & Cooling
Looking for a new motor for a utilitech pro 0313836 submersible pump
Most submersible pump motors are interchangeable.
A 230 V motor will run cheaper. Be sure to get the correct HP motor.
Oct 05, 2014 | Utilitech 1-1/2-HP 18-GPM 3-Wire 230-Volt...
Wire 230 volt air compressor wiring diagrams
On 230 volts you have 3 wires 2 are 115 volt and the third wire is ground. As long as you hook the ground wires together correctly the other wires don't matter. Usually the ground wire is either white or green. The black wires are hot (115 volts).
Feb 11, 2014 | Air Tools & Compressors
Proper wire hook up
black goes to L1 white goes to L2 make sure to look on side of motor to change from 220 volt to 110 volt either a knob or changing wires brown and white to different locations hope you didnt fry motor
Jul 26, 2013 | AO Smith 1.5 hp 3450rpm 48Y Frame 115/230...
Franklin Electric model 1103012431 Nameplate is 115/230. The motor is to run on 115VAC. Which terminals is the 115v to be connected to?
I live in Canada and this is how mine is wired. Your colour coding may be different so, if your motor fries, don't come looking for me. Use at your own risk. (The motor does work, at least.)
Standing behind the motor where you can read the faceplate, the electric box is on the bottom right. Inside that box, one power feed wire goes to ground, the black wire goes to the far left terminal closest to the motor and the white goes to the far right terminal. The 2 center terminals lead off into the motor. Mine is running on standard household 110 or 120V, whatever it is.
Aug 01, 2011 | Kitchen Appliances - Others
I'd like to know how to change a 115/230 volt pool pump motor to run on 115 volts after I've already change to internal possition to 115 volts
May 21, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Wiring diagram to convert Craftsman 5HP Air compressor
look on the motor cover or on the wiring cvr on mtr or on the inside of the wire termination cvr
Sep 21, 2009 | Air Tools & Compressors
Can i make my motor run on 220
DONT KNOW WHAT KIND OF MOTOR THIS IS BUT : IF THE MOTOR SAYS 115/230 VOLT AC ON THE INFO TAG AND IT HAS A LOW/ HIGH WIRING DIAGRAGM THEN YOU SHOULD BE ABLE TO CONVERT IT. SOME MOTORS HAVE A SWITCH ON THE FRONT FACE WHERE YOU REMOVE A SCREW AND ROTATE A SHAFT. IF THIS DOESNT HELP GIVE MORE INFO. JODY
Apr 19, 2009 | General Plumbing
Pool & Spa Logo
Top Franklin Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Franklin Pool and Spa Expert? Answer questions, earn points and help others
