Question about Measuring Tools & Sensors
Need a manua for Mstercraft Maximum Stud Fider. Cannot find what model is, it has LED screscreen, 9V battery, distance and depth finder, laser, 3 levels
5 Suggested Answers
  • 5100 Answers
SOURCE: I have a 9-volt Strait-Line
I suspect there are several models but I have one model. 1) Turn on the unit (if the green light is blinking replace the battery). 2) Calibrate the unit by holding it flat against the wall for 5 seconds until the red light goes off and the beep stops. Make sure you do not move the unit during the calibration or position the unit over a stud (try a spot 6-12" away from the corner of the wall - most studs are on 16" or 24" centers and the wood/metal stud is 1 1/2" thick). If the unit keeps beeping or the red light doesn't go off during the calibration, move the unit sideways 5-8" in case you are above a water pipe or other reason for "too deep a surface" for the unit.
3) Do not lift the unit off the wall or you will need to recalibrate it. Slide the unit across the wall. When the upper red light comes on and the beeping starts, that marks one edge of the object in the wall (stud). Continue until the red light goes off and the beeping stops. Mark the other edge of the stud by moving the stud finder in the opposite direction and marking when the red light comes on and the beeping starts. The center of the two marks is the center of the stud for securing anything to the wall.
If the beep persists over a 6" range, I'd check if you have any old cast-iron pipes or a door/window that was relocated in that wall. Repeating the test in a few places vertically along that spot of the wall will tell you there is a consistent large object in that location. Neither a filled in window or door will run the entire length of the wall but you could be finding the headers (the vertical framing of the opening would probably be ~4-6" wide (double or triple stud depening on the needs of the house design)).
I hope this helps.
(on another stud-finder that I borrow, you press the buttons on the right and left side to turn it on. Calibrate by holding it to the wall for a short while and then slide it across the wall. Note when the top red led lights and the beep starts. Repeat in reverse to find the other side of the stud.)
Posted on Sep 18, 2010
  • 157 Answers
SOURCE: how do you know when the strait line laser level
Hello. The instructions can vary from model to model, but most have a green indicator light that lights up when the unit detects a stud. There is a section in the manual (for most models) that will show/inform of the unit's individual method. Here is a link to the company's product manual support page. Click on your specific model to download the manual.
http://www.irwin.com/support-services/product-manuals
If this answer has helped, please rate it a four-thumbs up. Thank You.
Posted on Mar 29, 2011
xtremewaiana
  • 8 Answers
SOURCE: How to disassemble Strait-Line Intersect Laser Level With Stud Finder
Drop it again, repeat until completely disassembled
Posted on Jan 04, 2015
Testimonial: "senseless answer!!"
  • 34148 Answers
SOURCE: Need a manual for Mastercraft Maximum Stud Finder. Cannot find what model is, it has LED screen, 9V battery, 3 levels, laser'
Try Googling (mastercraft)(model)(manual) without parens.
Posted on May 17, 2017
How to use stud finder
While holding the stud finder on a spot on the wall where you assume there is no stud... press the button and hold and stay still for 10 or 15 seconds to calibrate. Then while still pressing the button start sliding sideways until the lights indicate the thickest point. You can use a pencil to mark the beginning and end. The center of that is the center of the stud. Measure 3/4 of an inch left and right of it to know it's sides.
Nov 24, 2013 | Black & Decker Distance Measurer with...
How replace battery in stud finder
It is very easy. Open battery compartment at the back and remove old battery and put new one in.
If you get stuck you can download manual from here:
Jul 01, 2012 | Strait-Line Intersect Laser Level With...
I have a 9-volt Strait-Line Stud Finder with 3 red LEDs and 1 green LED at the top end to mark the Stud Edge. I would appreciate it if I could receive step-by-step instructions on how to use the stud...
I hope this helps.
Sep 17, 2010 | Garden
How do i find a stud with the stud finder
Hello. The instructions can vary from model to model. Here is a link to the company's product manual support page. Click on your specific model to download the manual.
Aug 18, 2010 | Strait-Line Intersect Laser Level With...
How do you know when the strait line laser level and stud finder is on a stud
Jun 18, 2010 | Strait-Line Intersect Laser Level With...
Measuring Tools & Sensors Logo
29 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
