Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice build up on the bottom floor of the freezer
I have a GE side by side with ice and water dispenser in the door. I am getting a build up of ice on the floor in the bottom of the freezer. Ice maker seems to work ok, checked it to see if it is over filling, seems ok, and no water appears to be dripping off it when it is making ice. water also appears on the rear "shelf" in the freezer where the drain is located, but there does not appear to be anything (water/ice) inside the drain hole within the freezer
  • steviec Dec 05, 2007
    I have ice build up in the freezer side and no cooling on the other side. Have had it repaired twice already. Once it was the drain plugged, and once they just defrosted it. It lasted 5 months then has started doing it again.
    Sergeant:
    Champion:
  • 298 Answers
Sounds llik a defrost heater is open if you
have a VOM you can test it for continuity
Its probably behind a panel in the rear bottom
of the refrilgerator Should have a pan under
there to
Posted on Nov 21, 2007
Ice maker leaks on floor when I turn on after awhile
Hello:
is the water coming from the ice maker for sure?
It could be that you may have clogged defrost drain line and the water has no where else to go but the bottom of freezer..Defrost happens roughly every 8 hr or so...
Jul 11, 2017 | GE Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Ice build up on the floor of the freezer. A water leak on the water line supplying the ice maker and water dispenser??
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 15, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Water is slowly dripping onto the floor from the bottom of the freezer door. it is as if the door is full of water. any suggestions?
ARe the temperatures good inside the freezer? If they are not near 0° F, that is the cause of the water drip.
If it is nice and cold in freezer, check freezer floor, is there a sheet of ice? you have a clogged defrost drain, clear it or have it cleared for you.
Good temps no ice on freezer floor? possible water leak inside door from water dispenser
Aug 13, 2010 | GE GSH25JFR Side by Side Refrigerator
Puddle in front of TFX24CRS
If there is ice on the floor of the freezer, you have a blocked defrost drain. If no ice there, you are getting water from the water / ice dispenser, possibly down the back side of the door panel.
Seal the seams around the water catching recess at your dispenser with a bit of clear silicone. (corners and along the front edge seam with the front door panel.
Jun 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
Ice maker and now water dispenser does not work
Do you get water to the connector at the bottom of the freezer door ? if you do then the water pipe in the door is probably frozen - read new door ! if not then check thw electrical connector at the bottom of the freezer door as they have a habit of corroding.
Feb 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
393 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
