Question about Acer Computers & Internet
My aspire acer V5-572P-6454 is stuck in Boot manager. I'm having difficulty getting out of it.
GodSpeed
SOURCE: d2d recovery
Send me an e-mail and I will send you the fix! If you can't downloadload it from the below link. I had the same problem. The mbr was replaced, you have to add RTMBR.BIN to the MBR and it will work again. As long as you can get on your desktop and run this bat file you will repair the D2D again. Took me an hour to learn what was wrong, It works 100% though.
I have the Aspire 5610Z with the 2GB 533 mhz memory Stock.
Link #1
http://rapidshare.com/files/64293596/Acer_MBR_F10_Repair.zip.html
Link #2
http://www.sendspace.com/file/ngd4ql
matrix@gainbroadband.com
Posted on Oct 22, 2007
Junoon007
  • 1011 Answers
Hello Sir / Madam,
Many Acer systems come with the ability to press ALT+F10 to kick off the Acer Recovery applications from a special hidden recovery partition. Sometimes this won’t work and there can be a number of reasons.
1. D2D Recovery is “Disabled” in the BIOS (Main menu).
FIX: Enabled it and try pressing ALT+F10 again as the computer boots.
2. The Acer hidden recovery partition (PQSERVICE) has been removed or damaged. If the disk drive is a replacement drive then you won’t have this partition.
FIX: Unless you have previously imaged the PQSERVICE partition it will not be possible to use D2D recovery. You will need to restore from the Acer Recovery CD/DVD.
3. You have converted the FAT32 partition on the hard drives into NTFS. Acer D2D recovery won’t be available if you perform this conversion. Ironic that NTFS is a more desirable disk format to use but Acer won’t support this in their systems!
FIX: Restore your system from the recovery CD/DVD media.
4. The special Acer Master Boot Record (MBR) has become corrupt or has been overwritten with an non Acer MBR. As long as the PQSERVICE partition is there or you can get your hands on a couple of Acer service files for your model, then you can remake the special Acer MBR. Let’s cover how this is done.
  1. Disable D2D recovery in the BIOS. Can be found in the “Main” menu section. Save the BIOS settings and exit.
  2. Log into Windows with an “administrator” level account.
  3. Download ParTEDIT32.ZIP (registration required for download).
  4. Extract PTEDIT32.EXE from the zip archive and run it.
  5. Identify the PQSERVICE partition by its type or size. It is likely to be 12 or another custom value and is likely to be reasonably small in comparison to the other normal partitions - see the example below from a working factory default Acer. Click the Link below see the image full size. http://www.roundtripsolutions.com/blog/wp-content/uploads/
  6. 2007/10/AcerDiskRecoveryBroken_F031/hidden.jpg
    Change the type to “07′ (Installable File System NTFS, HPFS) and “Save Changes”.
  7. Reboot the computer and login with an “administrator” level account.
  8. You should then be able to open up a command prompt and navigate to the PQSERVICE drive.
  9. Enter the following command at the command prompt:
    mbrwrdos.exe install rtmbr.bin
    - You may have to search for these files and change into the relevant directory.
    Note: This step writes the Acer MBR, with mbrwrdos.exe and rtmbr.bin being the special service files.
  10. Close the command prompt window and reboot.
  11. Go into the BIOS again and enable D2D Recovery. Save the BIOS settings and exit.
  12. ALT+F10 should now start Acer Recovery as the computer starts.
  13. The Acer MBR ensures the PQSERVICE partition is hidden therefore there is no need to reset the partition type back to 07 - well there shouldn’t be if all has gone well. If you need to manually reset it then run PTEDIT32.EXE again, set the partition to 12, or whatever the original value was, and save the changes to complete the process. Reboot and it should now be hidden.
If Windows is unbootable, due to whatever issue, you can always use the Ultimate Boot CD for Windows (UBCD4Win) along with a copy of PTEDIT32.EXE to achieve the same results. Likewise, use UBCD4Win along with PTEDIT32.EXE if the PQSERVICE partition is being changed back to a hidden one by the existing MBR. We’ll leave that as an exercise for those who need to do it! It has been pointed out in the comments that UBCD4Win already has an application that will do partition maintenance, so checkout TestDisc if you go down that road.
If this is a new drive or someone has completely wiped the drive, including the hidden partitions, it may be necessary to use partitioning software to recreate the partitions that the Acer Recovery system is expecting! You’ll also need to restore an image of the recovery partition from a previously made backup, so it is worth making that backup image straight away while the laptop is still new and shiny, and certainly well in advance of any problem.
A final word or two of caution: take great caution when playing around with partitions on an Acer system… you have been warned… and remember to make the backup media disks as soon as you fire the computer up for the first time!
Thanks
Good Luck
Don't forget to rate the Solution!!!!!!!!
Posted on Mar 20, 2008
  • 244 Answers
SOURCE: All Drivers for Acer Aspire 3680
you can download from www.acerpanam.com
Posted on Oct 01, 2008
Somebody pls help me i need driver for ACER-Aspire-3680-Notebook-Atheros-3945abg-Wireless-Lan-Driver-v10.6.0.29-Windows-xp
tq
Posted on Nov 21, 2008
leecom72
  • 4806 Answers
Hi there
You want to restore your computer to its original settings without
recovery CDs?
This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 To activate the BIOS utility, press <F2> during boot up.
2 Check to see if Acer disk-to-disk recovery is enabled or not.
3 Make sure the D2D Recovery setting in Main is Enabled.
4 Exit the BIOS utility and save changes. The system will reboot.
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3 Refer to the onscreen instructions to perform system recovery.
Good luck and Merry Christams
Posted on Dec 24, 2008
Acer laptop stuck on Windows boot manager
1. Restart the Acer Aspire netbook by pressing the "power" button on the netbook's keyboard or by pressing the "CTRL," "ALT" and "DEL" keys at the same time.
2. During startup, hold down the "F8" function key immediately when you see the "Acer" splash screen and the option for entering "Setup."
3. Keep pressing the "F8" key until the "Advanced Boot Options" menu appears.
If you receive a "keyboard error," restart the Acer Aspire and repeat step 2.
4. Use the arrow keys to navigate to the "Safe Mode" selection on the "Advanced Boot Options" menu.
The arrow keys are located on the right-hand side of the Acer Aspire keyboard.
5. Press the "Enter" key to execute the "Safe Mode" selection.
The Windows operating system will now start in "Safe Mode" and you can perform a system restore or make needed changes to get your Acer Aspire to boot normally again.
May 25, 2013 | Acer Aspire 5742Z-4601 : 2GHz Pentium...
Unable to enter setup in acer aspire 5315
You do not say what OS you are running. You could try F12 at bootup to see if you can get to the boot manager that way.
Jan 15, 2012 | Acer Aspire 5315 Notebook
Will not reload windows 7
try to start windows on safe mode by pressing F8 prior to boot to windows, choose safe mode. Go to Programs and Features under Control Panel, and uninstal Dritek Launch Manager
Dec 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
Need to reset acer aspire 1200 desktop
The Aspire One is a netbook produced by Acer; it does not come equipped with a CD ROM drive, so a traditional hard drive reformat and Windows reinstallation is not possible without a peripheral storage device. An external USB CD or flash drive will suffice, however.Difficulty:Moderate
Instructions
    • 1 Plug in the external CD drive, then turn on your netbook and let it boot to your operating system.
    • 2 Open your web browser and go to the BootDisk website (see link in Resources). Download the Windows XP Fresh Install Bootable CD, then burn these files to a blank CD via your external CD drive.
    • 3 Ensure the files have burned to your bootable CD, then restart the netbook with the CD still in the drive.
    • 4 The netbook should boot to the CD upon the restart. Follow the instructions prompted for installation. Upon completion you will have a clean installation of Windows XP on your Acer Aspire One.
Oct 27, 2011 | Acer Computers & Internet
My acer aspire 4315 stuck at boot with white screen, when using external monitor it show acer boot screen and stuck there. I can press F2 for setup but nothing happen.
http://tim.id.au/laptops/acer/aspire%204715z%204315.pdf
Above is a link for your Service manual, inside is everything you need to know to troubleshoot and repair your machine, this is the manual that us engineers use to repair these units.
This could be your HDD, failed. Work through, the troubleshooting procedures.
Anyway try this below first. Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
May 14, 2010 | Acer Aspire 4315 Notebook
Yes, I've open my Acer Aspire and I am trying to
sorry.. it doesn't work like that you'll have to rely on the recovery managment tool that came with the computer. the reason it seems to get stuck(as you put it) is because it takes awhile to open the program and find the software needed to restore your computer. just be patient it should work just fine
Mar 31, 2010 | Acer ASPIRE T180-UA381B DESKTOP PC
Acer 5315 will not start up windows
check the BIOS setup screen, when you get the ACER screen press F2 or F10 or the DEL or END or ESC key one of those will get you into the bIOS SETUP. Once there revise the boot order, make sure the CD is first to boot then HDD. Also review to see if the BIOS recosgnized the HDD. the symptom you are describing may be a bad HDD.
Jun 02, 2009 | Acer Aspire 5315 Notebook
I have 1recovery **** named aspire 5610 dvd2 should i have a dvd1 disk also
go to http://www.sysresccd.org/Download
download the iso and burn it to a cd.
boot your computer with it
read the explanations coming up on the screen and when you see that you can choose how to start, type "wizard"
choose the top choice (auto)
when it starts right click on the desktop and start GPARTED.
one of the discs will be marked as "boot"
right click the disc called "recovery" (or the one that is not marked as boot).
choose manage flags
set it to Boot.
press apply on top (not always needed tho)
in the left picture (the one that opened from the start)
type reboot
remove the cd when you see the acer logo again.
the acer recovery manger should start.
May 29, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5100 Stuck in eRecovery boot loop.
You are going to need a boot up partition manager likeon the Ultimate Boot CD (ultimatebootcd.com). Boot to it, go into the partition program, then set the active partition back. Thanks and please take a moment to rate as fixya.
Feb 23, 2009 | Acer Aspire 5100 Notebook
Computers & Internet Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
