Question about Air Tools & Compressors
How to reassemble the power switch on model 92504 air compressor
How to reattatch the small spring in the power switch of model 92504 air compressor from central pneumatic
  • Air Tools & ... Master
  • 1,432 Answers
You can try but you can go online and find replacement pressure switches. The piping size is important my old one was1/4 inch, paid about $5-6 dollars on ebay. HF probably won't have part. If there is a model number on the switch body or inside cover that will help you. Al you need is one that the piping is correct and the switch Chas pressure range that you need. It is probably set for 120 psi off and 80 psi one. You can change it
Posted on May 19, 2017
Dewalt Aircompressor model 55168 type 2 is leaking on small hole under the adjustment knob how do you fix it from constantly leaking?
Assuming your talking about the regulater it is repairable. first remove from comp. disassemble bottom needle valve and seat by simply unscrewing round cap on bottom of reg. check to see if the valve is hanging up . normally due to air comp. oil blow by. clean lubracate and check for o ring or seat damage. remove 4 screws from top of reg. first loosen adjustment knob to release spring tention once you remove make sure diapham isnt torn or damaged clean lub. reassemble bottom valve push the needle down to make sure it releases and works properly. reassemble top diaphram spring adjustment and cap test if the through cleaning doesn't work and in my experiance it does 85 % of the time you can buy a rebuild kit for it. hope this helps it is a simple repair
Feb 24, 2013 | Dewalt Air Tools & Compressors
How do you fix stuck valves on a 86 Suzuki gs450l
Instructions
    • 1 Disassemble your engine down to where you will have access to the valve spring. You will need to remove the cylinder head cover, the rocker arms and the push rods. You will also need to remove the spark plugs.
    • 2 pixel.gif Next turn on your air compressor and regulate the air 60-90 psi, turn the crankshaft until the cylinder you are replacing valve seals on is on top dead center. Screw the compression gauge hose into the spark plug hole, attach the air compressor hose, your cylinder is now pressurized.
      The valves will stay in the closed position as long as the air pressure is holding it up.
    • 3 pixel.gif Using the valve spring tool, compress the valve spring and remove the valve keepers with a magnet. These may be stuck to the valve spring retainer and a little bump with the palm of your hand or a small hammer will jar it loose. Pack towels around the area so you won't lose the keepers into the engine. Remove the spring.
    • 4 Remove the old valve seal with pliers or screwdrivers and replace with a new seal. Reverse procedure to reassemble engine, use the magnet when installing keepers and after removing valve spring compressor tap the top of the valve lightly with a hammer to seat the keepers.
Jan 13, 2013 | Motorcycles
My EC12 will start up and hold air, after use the unit will not recycle on. Is this the regulator?
No, this would be the pressure switch. One pipe or small line to the tank, with power cord coming in and cord to motor. It is adjustable so try reducing tension on the spring first. If still no change replace pressure switch.
Dec 07, 2011 | Hitachi EC12 Portable Electric 2hp Air...
Can you tell me exactly how to fix my air shocks.....is there a manual pump?
System has no manual pump.system overview is this,air springs at all four wheels,electric valve at each spring,air line from these valves to a compressor under hood and lastly level switches that look at height and run compressor and open valves according to need.most likely the air spring bags are cracked causing leaks to system in turn which over works the compressor.best hope is just no power to compressor,so test for power and ground at compressor and if no power.power it up and raise veh or if there is power the compressor is smoked.
Oct 24, 2011 | 1995 Lincoln Continental
I stove door for the model # model plcs389ecg will not stay closed.
the door is of a double construction you should see four screwsaround the edge of the door.remove these the door should come apart. you will find that there is a small spring that has come off reattatch it to the smaal hole on the side of the door. reassemble the door replacing the four screws it should then work ok.
Jan 07, 2011 | Microwave Ovens
How do i adjust air pressure cut out
Square d recommends that the pressure switch be adjusted to specifications of the particular switch (which is sold in pressure ranges preset at the factory). The switch will be erratic it adjusted out of the factory setting range.
From Square D: (adjust the desired cut-in pressure first, then cut-out)
Cut-in: The large spring controls the cut-in pressure. To make adjustments, turn the nut clockwise (compressing the spring) to raise the cut-in point or counterclockwise to lower the point of cut-in.
Cut-out: The small spring is the differential adjustment and controls the cut-out pressure. To raise the cut-out pressure turn the small nut clockwise (more differential); to lower the cut-out pressure turn counterclockwise.
Sep 24, 2010 | Square D 9013FHG14J52M1X Air Compressor...
How to adjust went to cut on
you remove the cover you will see two spring one is larger than the other, and there are one adjusting nut on the top of each spring, bigger spring nut is for cut out and smaller spring nut is for cut in,unscrew the small nut is for quick cut in and screw the nut means longer time for cut in
Sep 25, 2009 | Square D 9013FHG14J52M1X Air Compressor...
Can any one tell me were how i can find the automatic level control on my 1994 town car
Description and Operation The rear air suspension:
  • Is an air-operated, microprocessor-controlled, suspension system.
  • Replaces the conventional rear coil spring suspension.
  • Provides low spring rates for improved ride and automatic rear load leveling.
  • Is standard equipment on the Town Car.
  • Is available as optional equipment on Crown Victoria and Grand Marquis.
The rear air suspension system has the following features:
  • The system is operational with the ignition switch in the RUN position.
  • Automatic rear load leveling has limited operation for one hour after ignition switch is turned to OFF.
  • The air suspension switch, located on the right side of the luggage compartment, must be turned OFF when the vehicle is on a hoist, being towed or jump started.
  • The Air Suspension warning indicator is located in the instrument panel, to the right of the speedometer.
    • The warning indicator flashes five times and then stays on when service switch is turned off or a system malfunction is detected.
  • The rear leveling system operates by adding or removing air in the springs to maintain the level of the vehicle at a predetermined rear suspension D ride height dimension, and is controlled by a control module (5A919) .
  • The rear air suspension control module also controls the electronic variable orifice (EVO) steering.
  • Refer to Section 11-02 for Description of the EVO steering system.
  • Air required for leveling the vehicle is distributed from the air compressor to the rear air springs by a nylon air line which runs from the compressor air dryer (5346) through a Y-fitting to each individual air spring.
Suspension, Computer Controlled—Town Car
Item Part Number Description 1 9C392 Compressor Relay Power Junction Block 2 5A897 Air Line (Attached to Brake/Fuel Bundle) 3 5319 Air Compressor With Regenerative Air Dryer and Vent Solenoid 4 5A897 Air Line to Compressor 5 5K761 Air Suspension Service Switch 6 14489 Data Link Connector 7 — Quick Connect 8 — To LH Air Spring 9 — From Compressor 10 — Y-Fitting (Part of 5A911) 11 — To RH Air Spring 12 5A908 Heat Shield 13 5A966 Spring Retainer Clip 14 5560 Rear Spring 15 5359 RearAir Suspension Height Sensor 16 5A919 Control Module 17 14018 Air Spring Solenoid
Control Module Power and Ground The control module (5A919) has the following features:
  • Power is provided by Circuit 418 and is controlled by the air suspension switch.
    • The air suspension switch is powered through a 15 amp fuse in Circuit 296 in Town Car.
    • AIR SUSPN PUMP (30A MAXI) fuse provides this power through Circuit 414 in the Crown Victoria/Grand Marquis.
  • Control module ground is provided through control module wire harness Pins 6 and 21, to the RH inner quarter panel sheet metal, near the control module .
Weight Added When weight is added to the vehicle:
  • The air suspension height sensor (5359) length is reduced from trim length, sending a "rear is low" signal to the control module (5A919).
  • The control module then turns the compressor on by grounding the compressor relay control Circuit 420. This restores the rear of the vehicle to trim position.
    • Battery voltage is provided to the relay coil by Circuit 414.
  • The control module opens the spring solenoid valves (5311) by switching Circuits 416 and 429 to ground. This allows pressurized air to enter the springs.
    • Battery voltage is provided to the air spring solenoid valves by Circuit 414.
  • Compressed air flows from the compressor, through the compressor air dryer (5346) airlines and spring solenoid valves into the rear springs (5560).
  • As the rear springs raise the rear body height, the air suspension height sensor increases in length until the preset trim height is reached.
  • The control module then turns off the compressor (through the relay) and closes the air spring solenoid valves.
Weight Removed When weight is removed:
  • The air suspension height sensor (5359) length is increased from the trim length, sending a "rear is high" signal to the control module (5A919).
  • The control module then opens the vent solenoid valve (located in the compressor assembly) by switching Circuit 421 to ground and opens the solenoid valves (5311) by switching Circuits 416 and 429 to ground. This restores the rear of the vehicle to trim position.
  • Compressed air flows from rear springs (5560), through the air spring solenoid valves, air lines, compressor air dryer (5346), and out the vent solenoid valve.
  • As the body lowers, the air suspension height sensor length decreases until the preset trim height is reached.
  • The control module then closes the vent and solenoid valves.
Control module operates as follows:
  • In general the control module uses a 45-second averaging interval to determine when compress and vent operations are needed.
  • However, door courtesy lamp switch (13713) inputs can override the 45-second averaging interval so compress and vent operations can begin immediately, if needed.
  • The 45-second averaging interval is used to keep the control module from making unneeded corrections.
  • When a vehicle at the correct rear trim height hits a bump, the air suspension height sensor output will read low and high in addition to trim until the oscillations die out.
  • If the control module were to correct for these "bump induced readings", system duty cycle would increase unnecessarily.
  • The 45-second averaging interval not only eliminates corrections due to bumps, but also eliminates unneeded corrections resulting from braking, accelerating, and turning. The control module tabulates the air suspension height sensor readings, and does not begin a compress or vent operation until the air suspension height sensor (5359) reads low or high for 45 seconds consistently.
  • There are more restrictions on vent operations than there are on compress operations.
  • To eliminate the chance of catching a door on a curb as the vehicle vents down, the control module will not allow any venting to occur when a door is open.
  • The control module does not allow any vent operations for the first 45 seconds after the ignition switch (11572) has been turned to RUN.
    • Even if a vehicle is extremely high in the rear, DO NOT expect it to vent until the ignition switch has been turned to RUN for 45 seconds.
Jun 24, 2009 | 1994 Lincoln Town Car
Air Tools & Compressors Logo
41 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
