Question about Kenmore Kitchen Ranges
How do I find model etc of Kenmore electric smooth top range
watugot
  • 290 Answers
SOURCE: How do you open the smooth top, on a Maytag range?
There will be 2 or 3 screws under the front edge of the top. Take them out and top will hinge up similar to the older models.
Unplugg the range before touching any wires. There is voltage on the thermal limiter on the element even when the switch is off.
Once you have access to the element you can check for power and continuity just like on an older range.
Post back with any questions. I will see if I have a manual on pdf.
Thanks/Mike
Posted on Nov 04, 2007
SOURCE: Smooth Top Electric Range
You didn't specify which type of smooth top - some, like the induction require special cookware. For the typical radiant type glass top nothing special is required.
Posted on Jan 03, 2008
jsrock516
  • 5911 Answers
SOURCE: I have a Kenmore electric
Here ya go...
This advice is for Electric Ranges equipped with glass smooth tops. If it becomes necessary to replace the cook top due to wear or damage, here's some helpful tips on how to complete the repairs yourself.
WARRANTIES: Most warranties DO NOT cover cosmetics. That is, if your cooktop paint starts to wear off, most manufacturers will not replace it. Warranties also DO NOT cover accidents such as dropping something on the top and breaking it. Warranties DO cover blistering, warping and heat related breakage (if you are using the recommended cookware). This is why it is important to follow all the manufacturer's use and care instructions that come with your range. I know this does not include ALL manufacturers, but this is true with most.
This is a recommended two-person repair job. Please read through the instructions carefully before starting the repairs, and follow any safety recommendations.
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. If the old cook top is broken, you will need to get rid of a much of the glass shards as you can and thoroughly vacuum the area around the oven box. Use extreme care when handling broken glass. Wear safety glasses and gloves.
3. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
4.On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
Unplug the cook top and leave the elements in place.
Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
Remove the surface element assembly leaving all the elements wired together.
Place the new cook top face down in the same manner and lay the surface element with wiring harness directly on to it and screw in place.
Install the new cook top back on the range and you are DONE.
5. If the wiring harness does NOT unplug, follow these steps:
There are a series of screws holding the element assemblies in place. Leave these assemblies wired together for ease of replacing. It is recommended that a second person holds the assemblies in place to support the wires until all the screws have been removed.
Lay the intact element assembly, with wires still connected, on top of the oven box. Handle the surface elements with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure.
If you have to remove the elements, individually, make sure you write down how the wires were connected to ensure you reconnect them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of. Use care when screwing into the new cook top. CAUTION: The screw holes are usually painted and a little force may be required to thread the screws. Do not apply too much pressure on the glass, or you can damage it.
Prop the new cook top in place and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
Lower the new cook top into place and secure with screws.
Good luck and I hope this helps.
Posted on Apr 08, 2008
SOURCE: Kenmore Electric Range Burner Stays on
replace the swich behind the knob.
Posted on Dec 06, 2008
  • 140 Answers
SOURCE: no electronic oven control guide for oven settings.
hello, here is the link to your manual.ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318200445en.pdf
and here is the link to the controls ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318200167.pdf.
Don't worry about it saying electrolux. They make some of the Kenmore appliances. Hope this takes care of you and don't forget to rate me. Thanks.
Posted on Jan 03, 2009
My Kenmore stove, model #79095680301, was baking some food when it made a loud popping sound. Since then, the control panel doesn't work (and we can't turn on the oven without the control panel). The stove...
Joe,
Sounds like you need to contact a qualified Kenmore technician. It could have burned out an element, wires to the element, etc., but you'll need to be fairly skilled to check these components.
Try contacting Kenmore directly here:
Kenmore Customer Care Customer Service Information
Feb 08, 2018 | Kenmore Electric Smooth Top Stove
While oven on range top front is very hot
I do not know the unit but check if the oven vent is near the front. It is also possible the door seal on the top of the door is failing.
Apr 13, 2014 | Kenmore Electric Smooth Top Stove
What is the current price for a used Kenmore electric range Model 790.95329302?
That is an electric smooth top range that was made by Frigidaire for sears. I would estimate the re-sale price at about $200-$250 in very good condition.
Aug 18, 2010 | Kitchen Ranges
I need help to replace the glass smooth top for kenmore model number 7909621340B. Can someone please help.
you can get the replacement top here
appliance parts solutions have the part# you need if you dont find it in the search call...good luck
Feb 09, 2010 | GE Spectra JBP78 Electric Kitchen Range
Lower element in Kenmore electric range does not work.
remove and take to appliance shop and they will match up for you. Make sure power is off before doing.
Feb 01, 2010 | Cooktops
Beep alarm goes on and shows code F3
Your oven temperature sensor has shorted out. It must be replaced. part number WB21X5301
Apr 07, 2009 | Kenmore Kitchen Ranges
Kenmore Select Clean Self-Cleaning Electric Range Model 6659580
This means you hace a problem with your clock. Take the back off the stove and then pull the ribbon connector off the clock and clean the terminals. If that doesnt fix it replacing the clock should fix it.
Nov 16, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Kitchen Ranges Logo
27 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
