Question about Whirlwind FH-778 Air Conditioner
AMANA AC unit Blows heat in cooling mode
Amana AC RHE 42A2D unit with heat pump. about 8yrs old Unit was working fine one afternoon then after a while I noticed the room was getting hot, the unit was pushing out hot air as if it was in heat mode. I was told that the coil on reversing valve can be ann issue so I replaced this.........Unit is still running hot Both copprt pipes running from the Handler to the Outside unit is very hot. Dont know what else to do to resolve it.
any assistance would be appreciated
  • 614 Answers
These valves do get stuck. They energize for cool and in the dead postion they heat. Your valve is stuck or not energized. Can you here it click or try to energize. If you dont hee the click you do not have voltage to the valve. The valve is powered thru the defrost board. So that might be your problem. If you have voltmeter. Take the two wires off the valve and turnit on cool you should get 24 volts. If you have 24 volts the valve is bad. If you do have voltage to the valve tap the valve while energized and sometimes this will loosen them up. If the board or valve is bad you will have to call a service tech. Russ There is only so much you can do.
Posted on Jul 25, 2009
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
Our older model amana wall unit is in the garage and worked fine until we programmed a new remote control garage door opener in there this morning. The ac unit was not on at the time but we went to turn it...
If it says E0 then what this usually means is that the unit was unplugged or power was cut to the unit while the unit was on. It then needs to be programmed again. If its the amana/goodman RSKP0009, you need to hold temp up and down arrows down together for two seconds then press off twice. It will take you into the programming mode. Settings are different for heat pump and electric heat models. If you just need a quick fix to get it to cool, I think you can get away with pushing the heat button a few times and then off. If you did it right the display should go off and the light by the off button will turn on. Press cool and it should work.
Aug 14, 2011 | Amana Heating & Cooling
Amana PTH153B50AM AC & Heat pump. fan works AC & heat don't. I was told by the guys who installed it to unplug it to reset the termostat but that don't work either. I turn it on cool &...
Jane, what you really need is the Owners Manual for you discontinued model AC/Heat Pump.
Call Amana Customer Support 1-800-843-0304 and they can furnish you one. Either by email attachment or by snail mail.
Hope this helps you. Please let me know.
Jun 20, 2011 | Amana PTH153B50AM Air Conditioner
Amana PTACAC/Heat Pump displays code ''Eo'' ..unit will turn on
the unit needs to be programed to operate in heat and cool mode
Dec 31, 2009 | Amana PTC093B35AE Air Conditioner
Noisy Amana Quiet Zone air conditioner
The compressor sounds like the springs inside are bad. You can live with this are get the compresor eplaced if it is over five years old buy a new unit. Compressor will cost more than a new unit. Russ
Jul 18, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Heat pump is not kicking in, no heat at 42 degree outdoor temp
HI,
Most likely has a freon leak , or a control problem causing heat to turn on, or if you have a heatpump the reversing valve has a problem.
Oct 10, 2008 | Amana PTH123B35AE Air Conditioner
Blows cool air
This is normal. To maximize the units efficiency the fan continues to run until all the heat from the coil is pasted to the circulating air.
May 24, 2008 | Amana PTH123B25AJ Heat Pump Air...
Not heating
Yes, the reversing valve has a separate coil. some energize on cool mode, some on heat mode. Has the thermostat been replaced? I find this a common mistake.
Nov 03, 2007 | Amana Comfort Zone 18M33PCEH Air...
Amana PTH153B35AK
This often happens if the unit is oversized or to close to a wall or object.
Feb 14, 2007 | Amana PTC153B35AK Air Conditioner
Heating & Cooling Logo
165 people viewed this question
Top Whirlwind Heating & Cooling Experts
AJMAL KHAN
Dennis Boxerman
Bill Long
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
