Question about Refrigerators
Error code E ref , rF freezer what does it mean
What does code Soaoo indicate?
Search Results
    S0A00 Set-Top Box Error Message Help - Comcast
    customer.xfinity.com/help-and-support/cable.../getting-error-code-s0a00...
    Learn what S0A00 on your Comcast cable box means and how to resolve this ... A number of signs can tell you if your computer may be infected with a bot, ...Missing: pioneer
    ref code S0a00 - Comcast Help and Support Forums
    forums.xfinity.com/t5/XfinityTV-and.../ref-code-S0a00/td-p/855021
    Jan 18, 2011 - If you getting S0A00 errors, that means you have signal issues, most ...fios is cheaper than comcast, can you give an example of how fios is ...Missing: pioneer
    Comcast Ref Code S0a00 - How Do I Fix It? - GeekDrop
Jan 23, 2016 | Pioneer Televison & Video
Kenmore elite bottom freezer refridegerator error code er rf
you could call a repairman but if it is fairly old then buy a new smaller refrigerator the smaller simple ones seem to last longer in the long run .
Jul 17, 2015 | Kenmore Refrigerators
What is wrong when I receive error code Er rF
Hello Anonymous!
Error code Er rF is an :Abnormality of BLDC FAN Motor for Freezer.
  • The freezer fan motor may be Defective.
  • Unplug the fridge for about 30 minutes and plug it back in, if the code appear again within 24 Hr , the Main Board might be defective too.
  • Check if the freezer fan is blowing normally, then the Main board has a problem.
  • If not, the Fan Motor is defective or both.
  • I would change the Fan first then the Main PCB
Good Luck,
JP
Jul 09, 2015 | LG Stainless Steel French Door...
OP ERROR CODE FOR ELECTROLUX REF
Hello scarter517 - Typically error code OP indicates that the freezer sensor is in an open position. A professional would need to check the wiring between the thermistor and board. If correct, the thermistor may possibly need replacing.
Nov 20, 2012 | Washing Machines
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
