Question about Mitsubishi Televison & Video
My 65in Mitsubishi diamond green light flashes over 100 times then I have to turn it back on but it has a rolling down screen and side to side jumping
Slinteriors
  • 8617 Answers
SOURCE: no picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jan 26, 2009
  • 9 Answers
SOURCE: mitsubishi hdtv1080 won't turn on. green timer light flashing
could be a lot of things really. when you replace the bulb, there is a switch that will prevent the tv from turning on if the cover isn't sitting correctly, by moving it that might have shifted so it would blink, but not turn on. if not, well get it serviced, sorry
Posted on Mar 18, 2009
  • 64 Answers
SOURCE: Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Posted on Aug 01, 2009
Slinteriors
  • 8617 Answers
SOURCE: my Mitsubishi diamond series 65
Try replaceing the DM capacitors that often cures that symptom. You can get the V26 DM repair kit from www.tvrepairworld.com the kit also contains the CD with detailed instructions.
Posted on Jan 08, 2010
  • 21 Answers
SOURCE: Mitsubishi Diamond TV power went out TV wont turn back on.
the regular problem is the convergence kit,
Posted on Jan 20, 2010
How do I reset my mitsubishi diamond tv? The green timer light is flashing.... I can't get the tv to come on.
If the light continues to flash with no picture and you still get sound, your bulb is out. Though it could be any number of issues. To reset a Mitsubishi, hold the power button down for approx. 10-15 seconds until you hear a faint click.
Jan 11, 2011 | Mitsubishi Diamond WD-65831 65" Projection...
THE GREEN LIGHT IS BLINKING ALL THE TIME
You have the one that the capacitors go bad on, this set is the most complicated set to work on call the pro's but expect as heafty bill, the chassis has to be pulled out and sent into Mitsubishi for a rebuild.
Sep 11, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi 65in DLP shuts off after a few seconds. There is no warning, and the green timer light is flashing after it shuts off.
My experience with this has been a fan is not spinning fast enough due to dust or wear. Cleaning the sets fans may solve your problem. If you can turn it back on in 1 minute and it does it again it is the fans. Good luck
Jul 22, 2009 | Mitsubishi WD-65000 65" Rear Projection...
I HAVE A MITSUBISHI DIAMOND SERIES TV. I REPLACED
Sounds like your TV is overheating. How dirty is the filter on the side? Is the fan on the back turning ok:? Does it look real dirty? Is so, a good cleaning is in order. Also, there is a fan under the lamp. Can you determine if it is working...the air flow may be obstructed (from the clogged filter) and it takes some additional time to cool.
Jun 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green power light blinking all the time on TV
After changing a defective capacitor, my TV still would not power up. After using a solution I found on this site, I held the power and volume up button down on the TV itself for several seconds, the TV powered up normally. I did notice that you had to do this while the timer light was flashing. Doing so after it went out was not effective. I initially only replaced one capacitor which was noticeably defective, and the flashing green timer light eventually returned. I will be replacing all 7 capacitors and resetting the TV. As mentioned above, the capacitors may look good but in fact may be defective. These are high temp caps which breakdown under a load but function normally when cold. Several people have mentioned replacing the capacitors didn't fix the problem. It appears that you must replace and reset using this method to repair some of these TVs.
Jun 06, 2009 | Mitsubishi WS-65615 65" TV
Mitsubishi 1080 diamond tv screen turns off
Your tv has a lamp inside (refer to your user's manual) make sure is in good condition.
Mar 21, 2009 | Mitsubishi Diamond WD-65831 65" Projection...
Mitsubishi hdtv1080 won't turn on. green timer light flashing
Mar 04, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Screen won't turn on --flashing green/solid green power light
Your main boards are bad. They are no longer available, You have to have the chasis rebuilt. Mitsubishi is rebuilding these chasis. You have to pull it without any cut wires & ship to Georgia.
tvdoctor
Jan 21, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
