Question about Exercise & Fitness
HOW TO CREATE A ELEVATOR - Exercise & Fitness
Unable to create new users
This needs to be done with elevated rights (administrator). Open start menu, go to accessories, right click on command prompt, run as administrator
Jun 08, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Will not drain
The drain hose for the dishwasher needs to exit above the 'P' trap. You also need to elevate the drain hose approx 32 inched up from the floor to create a drop for the water to exit.
Dec 25, 2012 | Dishwashers
E 7 error
1) this means 2 alternatives.
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
God bless you
Nov 07, 2012 | Exercise & Fitness
Crossfire wont back up from Windows 7
1.
Connect the external hard disk drive to the computer. Make sure that the external hard disk drive is powered on.
2. Create a Windows 7 system repair disc. To do this, follow these steps:
Click Start Collapse this imageExpand this im, type create a system repair disc in the Start Search box, and then click Create a System Repair Disc in the Programs list.
Follow the instructions to create the disc.
3. Note You must have a CD or DVD burner to create a system repair disc.
4. Start an elevated command prompt. To do this, follow these steps:
Click Start Collapse this imageExpand th, type command prompt in the Start Search box, right-click command Prompt in the Programs list, and then click Run as administrator.
5. At the command prompt, type the following command, and then press ENTER:
C:\Windows\System32\REAgentC.exe /disable
6. Disconnect the external hard disk drive.
7. At the elevated command prompt, type the following command, and then press ENTER:
C:\Windows\System32\REAgentC.exe /enable
Note This operation might fail. In this case, if you have to have access to recovery tools, use the Windows 7 system repair disc that you created in step 2.
8. Reconnect the external hard disk drive to the computer.
9. Start the Backup and Restore Wizard to back up your files and data to the external hard disk drive.
Hope this helps
Sep 26, 2012 | SmartDisk Crossfire Desktop (xf160f) 160...
I have heard that using an elevated feeder is good for dogs. Is this true? What makes them good to use?
There are people who both support and deny this claim. Many people insist that elevated feeders help create better posture, digestion and can relieve stress on your dogs hips and shoulders. Others say that elevated feeders can cause severe bloating in your dog. I recommend checking with your veterinarian first.
Aug 26, 2012 | Alessi Pets - Others
How do I create foot path maps on a topographic map? I have a Garmin GPSmap 76s. Thanks Rick
Are you check the user guide: GPSMAP76_OwnersManual.pdf
Additionally I suggest check in this link information about new apps in you GPS 76: expertgps.com/gps-receivers/Garmin-GPSMAP-76.asp
Apr 03, 2011 | Garmin GPS
My 7222 copier will not start it is showing f-77-2
M7 (Elevator motor) drive abnormality
• While the elevate tray is going
up, the PWB-F (Elevate tray
top face sensor) is not turned
OFF in the specified period of
time after the M7 is turned
ON.
down, the M7 is locked.
• The S2 (Elevate tray upper
limit switch) or the S3 (Elevate
tray lower limit switch) is
turned ON in the specified
period of time after the elevate
tray starts to drive.
The main
body stops
immediately,
and the RL1
(Main) turn
OFF.
M7 (Elevator motor)
PWB-A (Control board)
PWB-F (Elevate tray top face
sensor)
S2 (Elevate tray upper limit switch)
S3 (Elevate tray lower limit switch)
FS-114 F77-2 M11-FN (Elevator motor) drive
failure
• During tray ascending, PC14-
FN (Top face detection sensor)
does not ON after specified
time from M11-FN ON.
• During tray descending, it
does not reach the target
position within specified time.
• During tray descending, M11-
FN is locked.
PWB-A FN (Control board)
PC15-FN (Top face detection
sensor)
UNPLUG FINISHER AND SHUT WORK
Feb 23, 2009 | Konica Minolta Office Equipment & Supplies
Waypoint selection uses last location instead of current location
Backup all data and reset the unit. Hope this helps...
Jan 14, 2009 | Garmin Rino 120 2-Way Radio
Lexmark 640...says communication between comp and printer fails
ok..first thing
remove all s/w from print panel(through control panel)
then go here, look for lexmark icon, and download new drivers
reinstall with printer NOT connected to computer.
check printer for self test and test page.
reconnect to computer.
Mar 24, 2008 | Lexmark T 640 - printer - B/W - laser
Exercise & Fitness Logo
35 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
