Question about Everex Computers & Internet
What is the network key my everex step note laptop is asking for to connect to my wifi
Beni S-P
  • 1006 Answers
SOURCE: help me
Witch password???
Bios password???
Everex has a known problem with this model of laptop. It has been known to set its bios password by itself. It is a simple fix, but should be done by a proffesional. There is no charge for this repair at a Everex repair center.
If you want, this is what needs to be done. Remove the piece of plastic above the keyboard. Unscrew the 2 screws in the keyboard and lift the keyboard up( No reason to disconnect it ) Unscrew and remove the modem card in the center. There is 2 solder points c88 on the system board. You need to short those 2 points out while you press the power button on. This will reset the bios password. This should take someone about 5 minutes to do.
If this solved your problem please rate this solution as "Solved" or ask here again in order to find another possible cause
Posted on Oct 26, 2007
SOURCE: Enable Atheros AR5007 WiFi with UBUNTU 8.1 64 bit
you dont need to install drivers in vista . just search for new automatic updates all drivers will install automaticaly
Posted on Apr 05, 2009
firesnake09
  • 2923 Answers
SOURCE: ipod touch won't connect to wifi
There's a possibility that the password that the network was asking is the 'network key' (e.g. WEP or WPA-PSK). If this is the password that the network is asking for, you need to contact the administrator of that network and ask for the Network Key, because that network is secured. They put this kind of security to prevent unauthorized users to connect to their wireless network.
Have a great day!
Posted on Jul 01, 2009
SOURCE: How do turn on wireless on a everex step note
everex stepnote how to turn on Wireless network
Posted on Oct 23, 2009
SOURCE: DELL E6400 Connect to wireless Modem problem
I have the EXACT same problem on the same computer.
I'm not an expert so I searched online but didn't really find a lot of responses to this Dell issue. One suggestion was to turn off Intel PROset and let Windows manage the wireless connection.
That worked for me.
When in the Intel PROset menu, click on Advanced, then click on "Let windows manage your wireless set-up."
Alternatively, you can toggle between the two software by pressing F10.
This solution worked for me.
Posted on Aug 07, 2010
My next book wifi quit working.
hi Martha.
this is all i could find out.
First, make sure your laptop is 'not' connected to the modem/router via an Ethernet cable and follow the steps:
1. Go to "Control Panel".
2. Next go to "Network and Internet" and then "Network and Sharing".
3. Now click on "Manage Wireless Networks".
4. On this screen, remove all wireless connections by "right clicking" on it and select "Remove network" from the drop down menu.
5. After doing this, close the open windows and reboot the computer.
6. Once the computer is fully reloaded, scan for the "Wi-Fi networks".
7. Click on the available network that you want to access and select "connect".
8. It takes a moment, but then you will be asked to give a password for your Wi-Fi connection. Type in the password and click the "connect" button.
It should now be connected.
NOTE: If this doesn't work, you may want to reset your modem/router, and then once it is fully loaded again, repeat the above steps.
If this doesn't work, test seeing if your laptop will connect via Ethernet. If so, then your WiFi card may be going. You can either look to replace it/have it replaced, or get an external (plugs in via USB) WiFi card.
or try this link.
nextbook wifi problem
Dec 03, 2017 | Book Computers & Internet
How to set up netgear ex6100 wifi range extender
Overview:
This article describes how to set up a NETGEAR EX6100 in Extender Mode
The extender connects wirelessly to your existing WiFi network, and then it creates a new WiFi extended network and links the two WiFi networks.
Symptoms:
Cannot connect to extender
Extender broadcasting EX6100_NETGEAR_2GEXT
Extender broadcasting EX6100_NETGEAR_5GEXT
Extender cannot access Internet or network
Process:
1. Place your extender in the same room as your WiFi router.
2. Plug the extender into an electric outlet and wait one minute.The PowerLED lights green.
If the Power LED does not light, press the Power button on the side.
3. Make sure that the mode switch on the extender is set to Extender.
4. Use a WiFi network utility on a computer or mobile device to find and connect to the EX6100_NETGEAR_2GEXT or EX6100_NETGEAR_5GEXT (SSID) WiFi network.
Note: EX6100_NETGEAR_2GEXT and EX6100_NETGEAR_5GEXT are the default name of your extender's wireless networks, and by default it is unsecured. If you changed the wireless name or security in the past, connect to the new name or enter the passphrase when prompted. EX6100_NETGEAR_5GEXT is only visible if your wireless adapter is 5 GHz capable.
After the wireless connection with the computer or mobile device is established, the Client Link LED lights solid green.
5. Open a web browser window from the same computer or mobile device.The browser takes you directly to NETGEAR genie Smart Setup.
Note: If you are not automatically directed to NETGEAR genie, launch an Internet browser and type www.mywifiext.net in the address field of the browser. Enter admin for the user name and password for the password.
6. Select a 2.4GHz WiFi network to extend and click the Continue button.
7. Type the network passphrase (also called password or security key) in the Passphrase field and click the Continue button.
8. Repeat steps 6 and 7 to select a 5GHz WiFi network.
Note: If your router does not support the 5GHz band, click the Skip button.
9. Select Private Network(home network) or Public Network radio button, and click Continue.
Note: Selecting Public Network will enable NAT and DHCP on the EX6100. For more info on NAT refer to: What is NAT (Network Address Translation)?
10. Type the name (SSID) for your WiFi extended network in the 2.4GHz and 5GHz Network Name (SSID) field and click the Continue button.
Note: You can use the same security settings as your existing network by selecting the Use the same security mode check box.
The WiFi extended network settings are applied.
11. Use a WiFi network manager on a mobile device or computer to connect to the extenders newly created WiFi network.
12. Click on the check box and click on Continue to finalize the installation.
13. Unplug the extender and move it to a new location closer to the area with a poor WiFi signal.
Note: The location you choose must be within the range of your existing WiFi router network.
14. Plug the extender into an electrical outlet and wait one minute. The Power LED lights green. Connect to the extender network and enjoy the extended Wifi network.
May 02, 2014 | Computers & Internet
Doesnt ask for password when connecting to wifi
It might have been caused by an outdated internet card driver. Before doing anything, make sure that your wi fi is working. You can use a cellphone or any gadget or computer which can connect to your wifi connection. If it goes in without any problem, then do the following steps.
1. Do a system restore.
If you were to connect to the internet before using a wifi connection, then do a system restore and restore it back to the configuration when it was still working.
Click Start > Programs > Accessories > System Tools > System Restore
Follow the on-screen instructions. Select a restoration date when it was still working great. Launch the restore and let it restart by itself. Just wait for it.
Once it's up, check if it connects to the internet. If no go, then go to the next step.
2. Boot to Safe Mode with Networking
Restart your computer and tap F8 until you see the screen which asks you to boot to safe mode. Use the arrow keys to highlight safe mode with networking. Press Enter.
Try connecting to your wifi in safe mode. If no go, proceed to the next step.
3. Update your device drivers. Even if all works well. I mean all the two options above work, you still need to do this to avoid from getting the same problem in the future.
Install an automatic PC Drivers updater like RadarSync.
I hope this helps!
David
Feb 24, 2013 | Samsung - Laptop R480 / Intel Pentium...
Wifi driver
Everex uses linux operating system; use orinoco drivers for USB wifi/b. Orinoco USB wifi can do 900kBps. Available on ebay or amazon? If you have external dialup modem, you can download agere orinoco USB drivers.
Mar 03, 2012 | Everex StepNote LM7WZ Notebook
I have wifi from Verizon for my laptop. My wife took the laptop overseas. They have wifi there. The computer is asking for a "code". How do I find the code??
The code depends on which WIFI signal you are connecting to. For example if you are trying to connect to the WIFI in a hotel, then you have to ask at the help desk there how you should connect. Depending on where you are trying to connect people might not want you on their wireless and you wont be able to get a hold of a network key (code).
May 05, 2011 | Computers & Internet
How can get my wifi connections to my computer
things needed internet connection wi-fi router. wi-fi enabled laptop.
steps switch on router enable wi fi on your laptop check for availbale networks connect to the network. if asks key contact service provider
Jan 03, 2011 | Fujitsu Computers & Internet
My Vizio HDtv WIFI shows a good signal from my Linskys router but is "unabke to connect" even though I repeatedly enter the correct pass phrase, what is wrong?
Run the Linksys Wireless Network Monitor by double-clicking this icon 3719-001.jpg at the bottom-right corner of your screen. If you don't see the Wireless Network Monitor icon, click here.
kb_4285-001_en.png Step 2:
Click the Site Survey tab and select the name of your wireless network or SSID, then click Connect. In this example, we used a wireless USB adapter.
NOTE: images may differ depending on the model number of the adapter.
Step 3:
If the software is asking for a WEP key, enter the WEP key on the WEP Key 1 field.
If the software is asking for a WPA-Personal key, enter the WPA key on the Passphrase field
Nov 02, 2010 | Computers & Internet
How to connect samsung star GT-S5233W to internet and how to download games, to send mms to another phone? please answer me..
there is two way to connect internet1. is wifi and 2. is network provider. follow these steps if you have wifi connection
1. goto wifi and turn on the wifi
2. then press search buttun
3. then you will see the wifi connection
4. press to select the "connect" opntion
5. then save the configuiretion
note:- if the connection has password enabled then
goto "network key" option in network
configuiretion and write the password
and save it.
6. close all and reboot the your phone again
and repeat the step 1.2.3. and 4.
and for the network provider:-
1. ask for the internet configuiretion
to company you have the network
and they will send you the configuretion.
by sms.
2. install the configuiretion and your are
done.
Aug 13, 2010 | Samsung Star GT-S5233 Cell Phone
My Stepnote XT5000T WONT PICKUP AVAILIBLE
obviously the network card is installed but is it turned on. there should be a function key or switch to press...let us know if you need more
Nov 05, 2009 | Everex StepNote XT5000T Notebook
Oct 02, 2009 | Computers & Internet
Computers & Internet Logo
19 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
