Question about HP Garden
Where are points located on 14 hp kohler engine?
  • 5655 Answers
SOURCE: no spark on my 14 hp kohler engine
Sometimes there is rust on the crankshaft and the magneto can not pick up the signal. Leave the sensor on the engine, try cleaning the rust off the crank damper and then run a clean rag between the sensor and crank. The gap varies but a old fashion matchbook seems to work in case the sensor is loose. Good Luck
Posted on Jul 26, 2009
  • 61 Answers
SOURCE: No spark in JD lawn tractor engine
it could just stuck, loosen see if moves reset points.
Posted on Sep 07, 2009
SOURCE: 14 hp kohler engine (Cv14s 1451) runs good for 5
I had this issue on my 14hp kohler and it was the ignition module. Would run until it heated up then shut down.
Posted on May 18, 2010
  • 13 Answers
SOURCE: location of points in 1969 kohler engine
You didnt state which engine but they should be located on the side of the block to the left of the camshaft cover and about 3-4 inches below the exhaust pipe. There should be a rectangular cover with a wire running into it.
Posted on Jun 10, 2010
philwalker78
  • 608 Answers
SOURCE: Where is the oil drain
Hi, there is a push and turn plastic drain tap or metal bung directly at the bottom of the dipstick filler neck. Hope this helps, regards Phil
Posted on May 06, 2011
I have a 214 kohler engine john deere lawn tractor, what point wires go to hot and the ground
if that is the Kohler 14 hp motor it may have the spark control untit on the motor cover. I recently ran into one like that and switched the coil out from a blown 20 hp kohler engine. I just taped up the excess wires and made sure they were not near any moving parts. The mower ran fine after that. Kohler wants about $160.00 for a spark control unit. There have been no repercussions since making the switch.
Apr 21, 2014 | John Deere Garden
Kohler 14hp wont start not getting any fuel
Fuel solenoid, filter blocked, pump, carb leak check those
Oct 22, 2012 | Kohler pa-ch440-3031 gas engine, 4 cycle,...
No spark on my 14 hp kohler engine
Jul 26, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Electrical wiring for kohler engine
I have a Ford LGT with a 14 hp Kohler K321AS engine. Go to Kohler.com and download the service manual for the K321 engine. The manual covers all of the K type engines and gives diagrams and details of all the different types of ignition and electrical systems. It is free. JS
Jun 01, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Apr 28, 2009 | Garden
Garden Logo
27 people viewed this question
Top HP Garden Experts
solver2010
andrewdwhite
ray gallant
Are you a HP Garden Expert? Answer questions, earn points and help others
