Tried system recovery won't work still tells me did not load correctly
Emachines E528 laptop won't start
Try to boot it from safety mode.
and try to restore your system first.
If the restoring is failed, boot safety mode again and back up your files.
If you can't boot your laptop from safety mode, use anti virus program CD like norton.
Mostly, your system is messed up by adwares, spywares, and virus.
If all things fail, you should check your HD.
Jun 18, 2013 | eMachines E525 D260 Motherboard...
My Laptop won't fully start/blacks out/won't recover
You are lucky that this issue is operating system based from what it seems, try to work the recovery option, let it be that way for hours. It will move at some point.
Did you have a AV installed? If not it is crucial to have an anti-virus software installed on PC.
If all the efforts appear fruitless, contact Samsung; it could be a hardware issue as well... although they are less frequently observed.
May 29, 2013 | Samsung RV511A01 Notebook
Cant load software and Micro. outlook is not running correctly
Try a System Restore to a date before this issue. Not a recovery , a Restore.
May 13, 2013 | E-Machines eMachines Desktop PC
Installed new hard drive p105 s6064 now cd drive wont work dont have recovery discs
Dell recovery will not work in a Toshiba Laptop. Just make sure the boot order is set to CD/DVD driver first that will automatically start the CD/DVD driver when disc is loaded.
Apr 22, 2012 | Toshiba Satellite P105-S6104 Notebook
Will turn in but won't really start up, message pops up sayin I have problems on my laptop but it can't fix them? Read description
When your toshiba splash screen is showing on startup, press F8 continuously, then you should get some options, go to the one that says safe mode. After loading windows in safe mode click start, search, and type system restore. Open system restore, find a date where your pc was working correctly and click restore. If this doesn't do it on the toshiba spash screen (if you have a new enough laptop) there will be an option called system recovery usually f11 key, this will restore your pc back to its factory state and should resolve any problems your having. If you don't have that option go to and see if you can order a set of recovery disc's for your model, they usually run from $25-$30. Hope this helps.
Mar 01, 2012 | Toshiba Computers & Internet
The HDD of my Acer Aspire 5102WLMi got broken. I bought a new one, partitoned it, load the D: drive with Acer stuff from backup, mounted it in the laptop and started this with the recovery CD. This...
The HDD interface on this machine is a PATA so BIOS shows the correct interface as IDE 0. Upon loading up the recovery disc (I'm assuming it's a good condition genuine Acer recovery media), what it does is that it re-images the HDD to the default file system and automatically occupies the full partition of the HDD so if you have already re-partition it, the problem might lie right there. Try to do the following:
1. Erase all partition on the new HDD that you have purchased and format it with NTFS and try to load the Acer recovery discs again.
2. If that won't work, try to use a retail copy of Windows and check if it fully install Windows. If it does, try to create a duplicate copy of your Acer recovery discs, it might just be faulty and try again.
Good Luck.
Sep 04, 2011 | Acer Computers & Internet
Pc HP T620a recovery problems
seems like its wrong recovery cd or its corrupted. contact hp for new Recovery cds and tell them about your problem. Im sure they will help you.
you should have 2 disks one recovery pro disk and one os disk. start with the recovery pro disk.
Good luck.
Sep 04, 2008 | Computers & Internet
Continue to have windows not load after recovery, error
try getting a full copy of xp then use another application
like nero
if you need more advice on this get back to me
Mar 24, 2008 | Computers & Internet
Boot application from cdrom?
Recovery cds work only on the laptop at its original state, meaning not yet formatted, because the recovery disk is linked to the system to restore minor errors on the OS... Those cds have become useless since "he formatted the notebook", inside is not already the original files... Buy a windows XP installer and install it bu yourself... it is very easy....
Good luck....
Feb 02, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
