I have lost the sound on my Digihome tv - Televison & Video
Brand new tv and when I switched it on there is a huge black area shaped like a hill coming from the bottom half way up my screen - no sound
return for replacement or repair if try to repair or tinker with will void any warranty or return policy
Aug 15, 2016 | Digihome LCD TV
Remote codes
0281,0288,0285.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 08, 2014 | Digihome LCD TV
Can u get surround sound to play on Normal TV channels it's digihome 50" led smart TV
Sure are you using a preamp component system or do you want to play it on the tv if you do have a pre amp run the RCA cables to sterio input on amp or aux then in the setting of the amp go into sound and put the aux to 6.1 also remember that to use audio out on your tv
May 26, 2014 | Digihome LCD TV
The sound on my Digihome TV keeps going off and only returns by switching the set off then back on again. Any solution ideas please
Digihome is not a brand unto itself. It is manufactured by a Foreign Country (I believe it's in Turkey) by the name of Tesco. Very large territories for sales in Europe of the Digihome label and a half dozen others. You will probably have to find a TV shop that will look at it for you as they have no service nor even their own. website.
Oct 28, 2013 | Digihome LCD TV
Digihome tv
sounds like the sound board is not getting the proper power. would check the power board for worn out capacitors or leaking ones. cheap fix if you know how to use a soldering iron.
Sep 07, 2013 | Televison & Video
The sound keeps going off on my digihome lcd tv
will it come back on if you wrap it on the side? Probably a bad solder connection on the circuit board
Jul 21, 2013 | Digihome LCD TV
I have digihome tv has sound but no picture and nothing on virgin
is this happened either watching a tv channel or even watching dvd movies?. and then does the display only white screen or a totally black screen?.
Oct 16, 2012 | Digihome LCD TV
I have a Digihome DV940B freeview receiver, and wish to set it up with a tv and video how and where do I put the areal and scart leads
This depends on how you want to use your kit, and how many scart plugs you have in your TV and VCR.
If you have 2 scarts in your tv;
Aerial coax goes to digihome aerial in. Aerial out from digihome to aerial in of vcr. Tune vcr into Digihome.
Scart plug from digihome to tv.
Scart plug from vcr to tv.
You can then record what you have selected on your digihome box.
In my humble opinion, it's worth splashing out on a pvr; you have more functionality such as being able to record 1 program and watch another.
Regards
Zahc
May 05, 2010 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
