Question about Toro Garden
Toro 74325 drives very slow in both forward and reverse when the blades are engaged as well as when they are not. I check belts and pulleys and all seem fine. Could this be the Hydro gear fluid?
    Genius:
  • Toro Master
  • 2,500 Answers
Sounds like the belt tension is too loose. Check and tight it
more.
Good luck
Mai
Posted on May 16, 2017
Model 88173 snow blower-craftsman .Cannot engage forward or reverse drive gears?
Check drive belt. has it come off the pulleys or is it broken. They do those things once in a while. Check for broken shear pins in the pulleys as well
Feb 11, 2015 | Garden
Why would a riding mower have the blade turning slow?
If speed varies depending on how much grass you are cutting, look for loose or badly worn belt. If constant slow speed when engine is running at full noise can only be a slipping on pulley or clutch. Most likely clutch. Normally slipping generates much heat so look to your clutch or pulleys. If drive key has separated there will be damage to shaft with metal dust showing.
Jul 21, 2014 | Toro Garden
No forward/reverse motion
This sounds like you have a bad bearing in one of the blade hubs or idler pulleys. Check by turning each pulley by hand and see if it turns easily. Go around all the pulleys and blade hubs(where the blades mount) and check for ruff spots while turning, and that they all turn freely. Do this without the blade engaged, this will allow them to turn somewhat freely.
Apr 22, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Can you tighten the belt that engages the blade?
check for a spring loaded idler pulley that keeps tension on the belt out of place.
May 17, 2013 | Toro Garden
Mower starts but drives very slow or not at all, but fine in reverse.
If this is a hydro unit and it drives fine in reverse then there is no reason why it will not do the same in forward, there is a variable swash plate in the unit to change from reverse to forward, i would be looking at the linkages, if there is not enough movement it will greatly affect speed, check also that the pulley on top of the hydro is tigh and has not stripped the splines.
Apr 14, 2012 | Garden
We have Toro Lwa 100 Lawn Mower Model #26623. Power engaged, start mowing but lawn mower will not cut grass. You have to stop and let it rev up again to cut more grass.
This 1991-92 model is equipped with a blade brake clutch. When the blade slows down this means the belt is slipping. This slipping can be caused from a few different things.
Try adjusting the blade cable on the upper handle. this unit has an adjustable section. make sure the cable is not so tight that you snap it.
2 --A sticky pivot point under the belt cover
The belt cover in the back builds up with dirt and debris. Make sude it is clean under the cover and all of the pivots move freely. ( do this with the engine off)
3 --A sticky belt tensioner under the deck cover
The underside of this machine has a metal cover to protect the belts. Remove it and check that the blade belt idler arm is not frozen in place. this will cause the belt not to enguage all the way.
4 --A worn belt or belt pulley
The large flywheel and pulley can wear. Check this if the belt looks good.
This is all there is to the machine BBC system.
I hope this helps.
Get parts and more diagrams at a Master Toro Dealer like www.arcolawn.com
Jun 06, 2010 | Toro Lawn Mower With Toro Power Tools
Blade won't engage - mower starts and propells itself, but when the yellow arm is pulled and lowered to engage the blade, nothing happens.
The blade is probably belt driven, and the belt is either broken, need adjusting, worn that bad, or there is a pulley problem. Get it in the air and check that the belt tightens. It will not be completely tight, there should be a tiny bit of play when engaged.
Mar 29, 2010 | Toro Lawn Mower With Toro Power Tools
No power when drive is engaged
Hi
Check your drive belt and the tensioner pulley that holds tension on the drive belt. Its possible for the tensioner pulley to be sticking and not putting enough pressure on the drive belt causing it to slip.
Grab hold of that tensioner pully and make sure it moves in and out freely against the drive belt.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
24 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
