Question about Konica Minolta DiALTA Di200 Copier
Code COF32 - Konica Minolta DiALTA Di200 Copier
  • Konica Minolta Master
  • 6,161 Answers
ATDC Toner issue, the image unit mite need to be replaced. The image unit is the unit you can pull out on th righthand side inside the machine with to handels on it
Posted on Jul 26, 2009
Error code cof32
ATDC setting error - COF32, run F8 & use actual value, do not reduce setting value. open sie cover to reset.
Feb 14, 2011 | Konica Minolta DiALTA Di200 Copier
REMEDY TO SOLVING ERRORS COF32 AND CO650 IN KONICA MINOLTA BIZHUB 211.
to remove code "COF32" from your machine, simply change the developer with the new one. code will remove.
wish you best of luck............
Jun 12, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Fixing code cof32
The excess toner is under cleaning blade.Posible you emptied the developer.COF 32 ATDC sensor malfunctions.Tray ATDC gain level from 155 to 168.
Apr 22, 2009 | Minolta Office Equipment & Supplies
Monolta di 351 code cof32
C0F32
there is a sensor in drum unit
open drum unit
pull drum out from unit
see at bottom there is a small sensor
it is dirty
having toner on it
clean it properly
check its cable also
problem will bi removed
never forget to rate solution
MAIN AKHLAQ
Apr 22, 2009 | Office Equipment & Supplies
Fixing code cof32
You must have cleaned the developer in the right side of the image unit, the reason for the code because the sensor doesn't detect toner and developer. You don't mension the make and the model, I presume is a Minolta. If you tell me ,I can tell you how to sort that out.
GOOD LUCK.
Oct 30, 2008 | Office Equipment & Supplies
Code cof32
I removed Drum Unit, emptied excess toner, cleaned and installed. After short start-up code cof32 appeared.
Nov 05, 2007 | Minolta Office Equipment & Supplies
Konica Minolta DiALTA Di200 Copier Logo
580 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
