Question about Kitchen Ranges
How do you reset the main control board on a G.E stove Model#; JCB840EK1ES?
4 Suggested Answers
SOURCE: Gas stove Thermadore 36 inch Model PGR366 PL Oven wont bake but will broil
this may seem like a silly question if you've already tried it but have you checked the over temp breaker? If you have no idea what I'm saying there is a breaker on the back side of your machine. Of course Thermador is so kind to place it convenietly behind the back panel so you'll have to remove that. There should be a little red button in there somewhere toward the top middle half of the machine I should say. If you press that button it may work.
Posted on Nov 11, 2008
tigar2211
SOURCE: how to reset main control
CANDY CLD 135-86S will not boot, blinking lights two
Posted on Jun 09, 2012
  • 406 Answers
SOURCE: How do i reset my Maytag Refrigerator Model 7MI2569VEM2?
Have you tried unplugging the unit and waiting for a time? Also, make sure that that socket it is plugged into has not reset at the circuit breaker
Posted on Jan 12, 2015
I have a Kenmore stove electric was baking and the top part used for broiling came on now it's on even when oven is turned off it has a number on display e2 f3
Hello. The E2 F3 error indicates a high temperature condition. From what you're describing though, the main oven control board is malfunctioning. This board has relays on it that turn on the bake or broil elements. Sometimes, these relays can either become shorted or stick--causing whatever they control to stay on improperly. If I had the model number of your range, I could provide you with the part number for the control board, relay power board(if present on your model oven) and oven sensor if needed. Normally, at room temperature, the oven sensor will have approximately 1100 ohms of electrical resistance, +/- 10%. Remember, always remove power from the range before checking anything. There are only 2 things in an oven that control temperature--the main board and the oven sensor, which is connected to the main board by 2 wires. You will have to remove the back panel of the oven, locate the wires coming from the sensor and disconnect the connector joining the sensor to the board. Put an ohmmeter across the 2 leads of the sensor and take a reading. If the reading is near 1100, then the sensor is good--you can't check the main board. Important note: if your oven is more sophisticated, it might have another circuit board called a "relay power board", which might be causing the problem. The relay power board is just what it sounds like--a circuit board that has a bunch of relays on it that turn on/off everything--stove top elements and oven features. They are notorious for malfunctioning. The oven control board simply tells the relay board which relay to activate/de-activate. I hope I helped you!
Aug 11, 2015 | Kenmore Kitchen Ranges
What does F1 mean
The Fault Code/s will show up in the appliance Display
F0 - No Alarm Signal
Replace Main Electronic Control
F1 - Door will not Lock
Check door lock. Is Door Lock Getting Power
F2 - Door will not Un-Lock
Check door lock. Is Door Lock Getting Power Supply? Check Control Thermostat
F3 - Self Test Error
Disconnect Appliance from Mains Supply, Wait 5 Minutes and then Reconnect to Mains Supply
F4 - Shorted or Open Circuit Oven Temperature Sensor
Replace Oven Temperature Sensor, Check Sensor Harness Connection between Sensor and Control Unit
F5 - Relay Contacts Failed - Sticking
F6 - Power Board Temperature Too High
Check Correctly Installed, Check Cooling Fan Assembly, Ducting and Airways
F7 - Incorrect Polarity - Mains Supply
Check Mains Connection - Live & Neutral round the wrong way
F8 - Power Supply to Interface Problem
Check Wiring Harness, Replace Main Electronic Control
F9 - Procesor is Auto Resetting
Apr 05, 2015 | Electrolux White Westinghouse Stove Range...
Had power go off now er flashing on all burners can not reset
It's possible that you had a surge when the power returned that scrambled the controller's brain. Try disconnecting power and reconnecting to restore normal operation. Disconnect power by unplugging the stove from the wall or switching off the breaker that controls it at your main circuit breaker box. Wait a minute or two, then plug the stove back in or turn the circuit breaker back on. If the stove does not work after this, you may need a new controller board.
Aug 06, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
Loud pop and light behind stove. Stove top works, oven does not.
Good Morning Stephanie - Typically you may locate the model and serial number in the storage drawer, on the right side. Based on the symptoms you are describing, you may either have a communication error from the main control board or a faulty bake and/or broiler element. If resetting the unit did not solved the issue, at this point I would personally contact a professional to accurately diagnose the range to determine the root cause to reduce the risk of unnecessary parts.
May 26, 2013 | Frigidaire FEF316 Electric Kitchen Range
Frigidaire electric range model FEF379ACJ Does not work
You will need to replace the main control board/clock, on the unit. It controls everything on the unit. Here is the part to order.
Dec 01, 2012 | Kitchen Ranges
I own FRIGIDAIRE ES100/105 (electric stove and oven). Yesterday I was using the oven and suddenly I heard a loud sound. I went to check it I found out the both the oven and stove were off. And not working....
HI. The actual issue will be with the main logic board, which is where the main element control relays are mounted. These very important relays are damaged. The main board will need to be replaced, asap.
With that said, if you could be so kind; Please post the entire model number so that i may pull up all necessary part numbers needed, as well as, service manual links and diagrams to help with your repair.
Dec 02, 2011 | Frigidaire PLEF398AC Electric Kitchen...
F1 flashing on gas stove-manual says to push clear-where is clear button
HI. This actual code cannot be cleared by pushing the Clear/off button. This actual button will usually be located on the touch pad and is a basic cancel button. You can try to reset the entire control board by simply unplugging the unit for 5 minutes. This may correct the issue. If resetting dose not correct this fault, the necessary actions are to have the defective main PCB replaced, asap.
F1 - Defective control board(PCB)
May 23, 2010 | Frigidaire FGB24S5A Gas Single Oven
Oven not working after a power outage. Stove top DOES work.
HI, The power surge has, essentially, destroyed your main control boards circuitry. This will happen during a power surge. Most oven control board are not protected from this type of potential damage. To confirm, simply unplug your unit for 5 minutes. Once the five minute reset has passed, simply re- introduce power to the unit, and observe. If you experience the same issues after the five minutes reset, this will confirm the damage to the control board.
It must be replaced if the damage persist after the reset.
Dec 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
I am getting an F7 error on my Maytag stove model cre9600acw. What exactly does this mean?
Hi. Generally, this will require you to Replace the touch pad ,or if touch pad is part of the clock, replace the clock (ERC).
ERC = Electronic Range Control Board
Click here to purchase your black, or white main control board(ERC)
Dec 16, 2009 | Kitchen Ranges
Oven will not get out of the self-cleaning mode
Ok, unplug the unit for 5 minutes to reset the main circuit board. if the error continues to plague the unit, replace the control board.
May 31, 2009 | GE Ovens
Kitchen Ranges Logo
29 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
