Question about Building Materials
The number and cost of the tiles needed to tile the flthe dimensions used for the floor is 350mm X 350mm.will you use 350mm,356mm 362mm? in your calculations to determine the number of tiles to buy
    Loyalty:
    Visited the website for 30 consecutive days.
  • 478 Answers
Use 350 then add 12% to the number of tiles needed. You will have off guts breakage.
Posted on May 18, 2017
How to tile a floor
Billy, Click on and read the links provided to learn how to tile a floor.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://novafloor.us/installation-guides
http://novafloor.us/wp-content/uploads/2014/09/Installation-Guidelines-for-Direct-Glue-Tile_Grout-v2-10_2015.pdf
http://novalis-intl.us/wp-content/uploads/2012/10/LUXURY-VINYL-TILE-INSTALLATION-GUIDE.pdf
May 15, 2016 | Novalis Bella Tiles 18 x 18 Bella Napoli...
How do you drill through ceramic tile
Go to Lowes, Home Depot, Menards or reasonably good Hardware store. buy a ceramic bit. They are usually with the wood, steel and concrete bits. Small bits arent to pricy. If you need a larger hole like the on the shower pipe goes through, you will need a ceramic hole saw. Hole saws are coated with diamond chips and will probably cost $40 or more. good Luck
Oct 08, 2015 | Porcelanosa Ceramic Wall Tile: : Mosaico...
Can ceramic tile be installed over old ceramic tile?
You can install tile over tile. However here are the risks. The new tiles will require at least 3/16" of tile adhesive UNDER the tiles when put in place after they have been pressed into position. Additionally the trim around the tiles willhave to be removed and elevated the distance of the tile thickness and the 3/16" grout distance. The tiles if on the second floor of a home will easily losen due to the expansion and contraction of the home and the difference in the 2 types of tiles expansion and contraction rates.
It is not difficult to remove old tiles. You use a flat bar type scraping tool and the old tiles usually will pop right up off the floor. You will have to break maybe 2 tiles to get started but after that they are easy to remove.
My experience in my own fully tiled in all rooms 2900 sq ft home in the tropics is that I have to remove the old tiles as over time the new tiles losen on top of the old tiles. I have tried it several times and have had at least 1 tile come loose each time.
Thanks for choosing FixYa,
Kelly
Oct 05, 2010 | Home
Wrong floor tile adhesive used. Contractor used timber floor adhesive instead of concrete. Some tiles cracking and adhesive not drying?
it depends on what kind of tiles they were. If they were soft tile, then they may crack anyway if the floor is not level, also if he made the floor uneven by using the adhesive they can crack. Many soft tiles are peel and stick and no adhesive is needed. If they were hard stone tiles then he should have been using grout to stick them down and grout the cracks in between as well. It sounds like you need to have someone else come in and re-access the problem as I can't see the whole situation, but it sounds like the tiles may need to come back up. You can either get the same guy to come back and fix his mistake or get some one else to fix it then go after him to messing it up. If you want to choose another person I recommend looking at www.superpages.com.
May 26, 2010 | Saws
SteamVac F5914-900 SpinScrub Upright Vacuum: Is it ok to use the hoover steamvac on tile floors...
Yes, your Steam VAc will work on tile floors. You'll want to remove the rotating brushes and install the Bare Floor Tool attachment - Hoover part number 48417003
May 16, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Walk-in shower floor problem
They probably use wrong adhesive that is not hard yet and have tenedency under pressure to squeze out between grout lines. Yes they need to address the problem immediately.
Jan 14, 2010 | Home
Building Materials Logo
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
