Question about Vacuums
Vacuum wont start when switch is turned on - Vacuums
  • 1,830 Answers
What type, make of vacuum cleaner is it?
It could be the motor or that it is not getting sufficient electrical power.
Posted on May 16, 2017
Testimonial: "karcher tornado cv 30/1"
Shark professional nv355 wont turn on
could be the motor thermostat. Make sure the unit is clean. No dust build up in the filters etc. Then here are the motor reset steps.
Motor Thermostat needs resetting
In order to reset the Motor Thermostat:
  1. Move the Power Button to the "O-Off" position
  2. Unplug the vacuum
  3. Check for a clogged hose or filter; unclog the hose and replace the filter
  4. Wait 45 minutes for the vacuum to cool; then plug the vacuum
  5. Turn the power switch to the "I-On" position to start the vacuum
  6. If the vacuum still does not start, contact Customer Service at 1-800-798-7398
Jan 10, 2018 | Shark Vacuums
Why wont my vacuum start when I turn it on
If you are in the UK replace the fuse in the plug
Oct 19, 2014 | Vacuums
Why rainbow vac wont turn on
There are numerous reasons. If there was no smoke or burning smell, first try a different outlet. Then you can try wiggling the cord and check cord for damage, if you can get it to start and it turns off again cord is loose or damaged. Try the switch, sometimes switch wears out, if it is not making a click sound or is very loose it may be the switch. The most common reason for an E series to not start after working just fine is a broken actuator on the water basin or missing from the bottom of the vacuum. There is a raised part on the water basin that depresses a little black plastic actuator on the bottom of the vacuum. This is a safety switch to make sure the water basin is there so the vacuum will turn on. You can try pressing in on that and trying to start your vacuum, if it starts you will need to check and see if the part is broken off of your basin or if the little black actuator is missing. You can see pictures here.
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 10, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Hoover spirit 900 canister wont turn on?
see this causes and fix it. God bless you
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
Sep 27, 2012 | Hoover Vacuums
The kirby wont start no power
Start by checking to insure you're getting proper voltage through the cord. Make sure the bag emptor and front brush roll nozzle are installed properly as each must activate the switch for it to run. It could have a defective switch.
Jun 20, 2010 | Kirby G6 Bagged Upright Vacuum
The brush bar wont spin on my dyson dc 25... i
Hi its Darran at Dyson.
Simply switch the machine off and stand it upright. Press the brush bar on/off switch once and then turn the machine back on.
When you release the machine into the vacuuming position, the brush bar should start to turn again.
If you still having problems, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Jan 08, 2010 | Dyson Ball HEPA Upright Bagless Vacuum -...
Agitator brushes wont turn even after cleaning
the brushes will not turn even wen the switch is turned on
Aug 10, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Wont turn on
Sounds like something is not in the right place. Tghere are safety switches, one on the front where the nozzle mounts, if it didn't get on right, it may not be pushing the switch. There also is another switch where the bag mounts onto the base, if it isn't pushed all of the way on, then that switch won't work. But if either one isn't set, then it won't start up.
Dec 15, 2008 | Kirby G4 Bagged Upright Vacuum
Vacuums Logo
51 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
