Question about Dimensions Office Equipment & Supplies
If I would like to use an A5 page as my scale dimensions length and width of my grettingsb card?give your scale unit format
SOURCE: i need the following info
Exterior Dimensions
Wheelbase
2519 mm
Front Track
1527 mm
Rear Track
1503 mm
Overall length
4159 mm
Overall Width
1763 mm
Height (unloaded)
1415 mm
Ground clearance
n
Unladen weight in kg / gross weight limit in kg
1375 kg / 1935 kg
Posted on Nov 05, 2008
SOURCE: Dimension and Scale Factor
125/180 = 1.5625
Posted on Mar 19, 2009
  • 5 Answers
SOURCE: I have an argos 214. Running windows XP. When I
when u want to use it, set it as default printer. then the setting of the design will not go back. and don't set anything setting on the printer, use program to amend the location of the design.
Posted on Jul 31, 2009
relaga58
  • 158 Answers
SOURCE: my office room model dimensions are
u need 1 hp unit
Posted on Nov 25, 2009
  • 10865 Answers
SOURCE: 1998 acura cl 3.0l battery dimensions? height,
Hello. 12 V, 720 cranking amps at 0 degrees F, 910 cranking amps at 32 degrees F, 9-5/16 x 6-13/16 x 7-5/8 in. tall, 31.7 lbs., Joe
4 thumbs up please. ty
Posted on Oct 27, 2010
Rectangular prism is made from centimeter cubes. What are the dimensions of the prism width x length x height? What is the surface area of the prism? What is the volume of the prism?
Dimension of the prism is the number of cubes in width x length x height.
Surface area is 2(w x l) + 2(l x h) + 2 (wxh)
Volume is the number of cubes.
Good luck,
Paul
Dec 07, 2016 | Office Equipment & Supplies
IF LENGTH and WIDTH are given How to find Hight
Never. Even if it a regular shape.
Oct 18, 2016 | Miscellaneous
The perimeter of a rectangle is 600 yards. what are the dimensions of the rectangle if the length is 20 yards more then the width
160 by 140
The perimeter is 600, so 2w+2l=600 where w is the width and l is the length.
Divide both sides by 2: w+l=300
The length is 20 more than the width: l=w+20
Substituting in the previous equation: w+(w+20)=300
Collecting terms: 2w+20=300
Subtract 20 from both sides: 2w=280
Divide by 2: w=140
Thus the width is 140. Substituting into the equation for length: l=140+20
Simplifying: l=160
The width is 140 and the length is 160
Sep 15, 2014 | MathAid Algebra II
How do you solve a rectangle is eight inches longer than its width. find the dimensions of the rectangle if the perimeter is 60 cm
The rectangle is 11cm by 19cm.
The perimeter is 60, so the width and length must add to 30. The length is 8 more than the width, or width+width+8=30. Solve that for width, then you can calculate the length based on the width.
If this is homework, be sure to show your work.
Oct 11, 2013 | Lands Phones
I need the following info for my 1999 Audi S3 in relation to the tailgate dimensions: Height.......cm; Length........cm; width.........cm; wight.........kg
Exterior Dimensions
Wheelbase
2519 mm
Front Track
1527 mm
Rear Track
1503 mm
Overall length
4159 mm
Overall Width
1763 mm
Height (unloaded)
1415 mm
Ground clearance
n
1375 kg / 1935 kg
Nov 05, 2008 | 2005 Audi A3
Horizontal White Banding
Most likely cause is that a roller has degraded during storeage. Measure the distance from the centre of the first band to the second and from the center of the second band to the third. If this dimesion is fairly constant you can work out exactly which roller is causing the problem. The most likely culprit will be the Photo Conductor Unit. This will give a large dimension - (approx the 29cm??) A service manual should give you the dimensions (circumferences) of the rollers within the machine. If you have a spare pcu around, put it in and see if it makes ANY difference.
May 13, 2007 | Konica Minolta magicolor 2300DL Laser...
22 people viewed this question
Top Dimensions Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Dimensions Office Equipment and Supply Expert? Answer questions, earn points and help others
