My screen is dosen't work - Computers & Internet
The sound from the left output device dosen't work
I would also first switch left and right to check the cables
Feb 20, 2013 | Simmons SD7PK Electronic Drum Set
1999 grand am speedo dosen't work. put a new senser in still dosen't work
Sounds like you have some electrical corrosion in a connection somewhere in that system causing the low voltage. Take the connectors apart and clean them and that should help
Jan 07, 2013 | 1999 Pontiac Grand Am GT
The screem dosen,t work
You may try: turn off the brake cable detection of your Car DVD player in setting;check your screen;check power supply of screen
Jul 17, 2012 | Pioneer AVIC-N2 Car DVD Player
Heater dosen,t work
you might have a problem with your heater core ,also check your radiator and make sure it is full if you are low on water that will also cause cold air to blow or your actuator witch is a control switch that opens the vale to let hot water pass through giving you hot air good luck
Nov 30, 2011 | 1997 Chevrolet Lumina
The phone screen has gone white, i can't see anything...
your phone lcd need to replacing.in some cases connectors have problem,it must test with a new lcd & then problem will solve.
Jun 04, 2009 | Nokia N70 Cellular Phone
Motorola W375 screen
Hi. You can replace the LCD screen. See http://www.formymobile.co.uk/proddetail.php?prod=w375lcd
Nov 14, 2008 | Motorola Mobility W375 Cellular Phone
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
