Question about Garden
We are trying to adjust the valves on a 4310 JD tractor cannot find the inspection hole on the tractor?
  • 61 Answers
SOURCE: No spark in JD lawn tractor engine
it could just stuck, loosen see if moves reset points.
Posted on Sep 07, 2009
  • 3600 Answers
SOURCE: somebody knows the valve clearance spec for the 3
try .16 for intake and .18 for exhaust should be pretty close you can tighten up if you have feeler gauge while running, this is a cold setting and is average for most all three cylinder engines.
Posted on Oct 17, 2009
SOURCE: International wheeled tractor model V533 clutch adjustment
dont know
Posted on Nov 13, 2009
fuxed
SOURCE: valve clearances for jd la
0.08mm-0.13 mm- intake top 0.13mm-0.18mm- exhaust bottom
Posted on Nov 17, 2009
nova2nv
  • 197 Answers
SOURCE: jd 05 i think 4310 wont move fwd or rev trouble
This is fault code 1.Fault-forward pedal.Cause of fault-Voltage signal out of range.Result of fault-Output current zero machine does not drive.Required action-get signal in range,,,recalibrate sensor.If this code does not match up to your symptom let me know and I will look into it.
Posted on Nov 19, 2009
How to remove starter jd 4310 ?
It probably the starter relay, or ignition switch. What does it do when you try to start?
Jul 23, 2014 | John Deere Seat 4210 4310 4410 4510 4610...
JD 4310 tractor hydro problem
Jeff I am having the same problem. Have you found a fix for this yet? your post is right on but for some reason we are the only two withthis problem and my local jd dealers have never seen this. , Brent
Jun 16, 2012 | John Deere Seat 4210 4310 4410 4510 4610...
John Deere indicator code
Call your JD dealer they should help you it could be as simple as a light bulb out.
Oct 22, 2011 | John Deere Seat 4210 4310 4410 4510 4610...
How do you adjust the steering toe on a L130 lawn mower?
The L130 off of the show room floor does not have adjustable drak link / tie rods.
One of the 300 hour inspections is to inspect the steering pivot bushings. You jack up the front from the center and check for play of the pivot bushings by teetering the tie at the 6 and 12 oclock positions. If you get a lot of movement the bushings are bad. If the bushings are ok (I doubt they are) then you can also add adjustable tie rods
1 GY20492 ROD, RH DRAGLINK ASSY. ADJUSTABLE
1 GY20491 ROD, LH DRAGLINK ASSY, ADJUSTABLE
http://cgi.ebay.com/John-Deere-Tie-Rod-Drag-Link-L110-l120-L130-L-Series-/280669312038
They are more expensive at JD ($66.00)
Just note the pivot bushings do NOT show up on any JD diagram but they do exist. Check with JD parts. They most likely know the PN from memory.
http://jdpc.deere.com/pimages/MP29/MP29762________UN16SEP02.gif
Thanks for choosing FixYa,
Kelly
Jul 27, 2011 | John Deere 22HP VTwin 48" Riding Mower
My John Deere 4310 compact tractor hydrostat transmission does not work. I got on top of a tree stump and now it will not move. Trouble code light flashes one long then three short flashes. Please help.
You likely knocked a wire out of the forward or reveres potentiometers,which are located under the right floor pan and are attached to the foot pedals.If they are in place then they may have bee hit and now need to be re-calibrated,if so call your J.D. dealer.
Jun 14, 2010 | John Deere 4020 Gas & Diesel Tractor...
Jd 05 i think 4310 wont move fwd or rev trouble code flashes four times one short ,long, short, short?
Nov 19, 2009 | John Deere Garden
JD X320 blades stay engaged, always. Narrowed it
Hi you can adjust the gap on these clutches , The recomended gap is 0.10 thou you slide this size feeler guage into the hole on the side of the clutch there is three holes and three adjusting nuts you have to try and get it even .
Hope this is some help
Mark.
Jul 18, 2009 | Garden
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
