Question about Hitachi Televison & Video
10 OHMS 5 WATT O/C - Hitachi Televison & Video
  • 585 Answers
The resistor is open? Look for the resistor to be in series with a diode and check to see if the diode is shorted. The resistor and diode should be part of a power supply circuit. Check to see that it is not driving a short. If there is a short, it is probably the sound chip or maybe the vertical. You can't just replace the resistor without actually finding and correcting the cause or you'll just fry another resistor.
Hope you find it.
Posted on Jul 25, 2009
10w 22rj wire wound resistor
When thosse resistors (precharrging of main input filters) burn up there is major damage. The IGBT's are usually gone... replace with APT28GA60BD15... the switching regulator IR2153 is gone... one or more of the 2SA1020-Y and the 2SC2655-Y gate drivers are gone. One or both of the DL4148 speedup diodes for the IGBT gate drives will be gone. The Wirewound ceramic resistors either 10 or 22 ohm 10 watt radials... Use:
http://www.mouser.com/ProductDetail/Ohmite/TWW10J20RE/?qs=GcOFt9%2fAxQHny%252b35G6iehQ%3d%3d
This is 20 ohms, however Behringer uses from 10 to 22 ohms in these units... 20 works fine as does 10 ohms. If you have toruble getting schematic let me know.
Aug 22, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Put new pa speakers in church 2 1000 watt tied 2gether and 2 300 watt. tied 2gether. the pa amp only has 250 watts with 6 mics connected and a cd player which plays fine. every time the mics are used if...
hi,
You have to check the ohms of the speakers all spekers should be 8 Ohms or above. if not it will overload the amplifier at high level. The minium ohms impedence of the amplifier is 4 ohms. If you connect two 8 ohms speakers together then the effective ohms will be 4 OHMS then the amp will handle the speakers. If you connect two 4 ohms spekers together then the effective ohms will be 2 Ohms, this will overload the amplifier. You will be able to connect two 8 ohms speaker to left channel or right channel of the amplifier. Check the speaker spesifiction to know its ohms. Make sure all the speakers have an impedence of 8 OHMS or above
OK
Aug 19, 2011 | Radio Shack 250 Watt PA Amplifier...
How many rms does my amp have.....??????
4-channel, 4 ohms: 4 x 50 Watts
4-channel, 2 ohms: 4 x 90Watts
Stereo, 4 ohms: 2 x 180 Watts
T.H.D. : Frequency Response: 10 - 25KHz
S/N Ratio: >90dB
Channel Separation: >50dB
Dimensions: 13"L x 9.9"W x 2.25"H
Zapco I450 Zapco I 450 iForce Series 4 Ch. 360 Watt Amplifier
May 22, 2011 | Zapco I-450 IFORCE SERIES 4 CHANNEL CAR...
I need to know the ohm rating for the speaker in a
Judging from the "10D", that most likely means 10 watts. 6.5 inch speaker, probably 8 ohms. Most amps of this nature have 8-Ohm speakers.
Their 12-watt and 15 watt amp have a 6.5". Their 20 watt amp has an 8". The 80 watt has a 12".
Hope this helps.
Mar 28, 2010 | Peavey Pv 2600 Power Amplifier
Can i run just 2 subs on this 1200 watt kenwood 5-4-3 and if so what way will i get the most power, i mean do i bridge it or pute the speaker wires in other ports
you can run 2 subs given that you dont go over 2 ohms of resistance and that the subs are rated at 1000 watt max each around 4 or 500 watt rms. if your not sure about ohms dont bridge it and get single voice coil subs. this amp is capable of about 700watts constant power 1200 max spike if the voltage stays at 12 or higher.
Feb 05, 2010 | Kenwood KAC-X650D Car Audio Amplifier
Amps on woofers are fine just won't hit
your probably making your amp run to low ohms if its a 2 channel amp bridged to one channel you can probably only run it at four ohms
Also seeing as your subs are 2ohm dvc you can't wire them individually to 2ohm and use each channel separately. So i'd recommend buying a 2ohm stable monoblock or running it at four ohms. a 1400 watt amp'll still pound at 4ohms and it'll extend your amp's life span
Aug 29, 2009 | Pioneer GM-7200M Car Audio Amplifier
I have a jl 1000/1 mono amp and my low ohm light was on and making a buzzing sound and found that there was a resistor that one of the terminals broke off and now no matter where i look i cant find the...
The 5 ohm could be challenging, what you could try is to get 2 10ohm 3 watt and put them in parallel. Will be 5 ohm and 10ohm is easy to get
Hope that helps
Jul 26, 2009 | Car Audio & Video
Panasonic T.V. model number PT-47WX42F no picture or sound
R800 open on power board next to the relay.the resistor value is1.5 ohms 10 watt resistor.
Jul 15, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Excessive brightness with retrace lines
Here are the values:
RY04 >>>> 68 ohms >>>> 1 Watt
RY04A >>> 47 ohms >>>> 0.5 watt
RY02A >>> 330 Ohms >>> 0.25 Watt.
All resistors should be 5% tolerance.
Apr 17, 2008 | Apex Digital GT2715DV 27 in. TV/DVD Combo
Hitachi 53uwx10b
Hitachi has created a repair kit part# X480293 for this problem. It includes: (2)STK392-150 convergence ic's,resistors RK42 = 3.3 ohms,RK46 = 1.8 ohms,RK50 = 2.7 ohms,RK54 = 1.5 ohms,RK58 = 3.9 ohms,RK62 = 2.2 ohms,all 1 watt resistors.
Aug 20, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Televison & Video Logo
75 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
