Make :Sony Model:KDL-52XBR6 Serial:8014808 TV shows fine but sometimes would have vertical lines going across the screen
SOURCE: Yamaha YPG625 screen shows only vertical lines
I brought the keyboard into a local service technician. He told me that he had to remove about 50 screws but the solution was simple. He unplugged and reconnected the ribbon connector. It apparently was not making good contact.
Posted on Oct 21, 2008
SOURCE: Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Posted on Jan 19, 2009
SOURCE: Vertical colour lines on whole screen
The problem is that the panel has failed. Apparently this is a common problem with LCD TV's between 18 mths and 3 yrs old. If it survives over 3 yrs it is likely to last for a few years longer. The cost of replacing the panel is more than a replacement TV!
Posted on May 26, 2009
vinnyq
  • 157 Answers
SOURCE: Sony Bravia KDL-40S2000 thin vertical line
If the line is present in all inputs and modes, there is a problem with the LCD Panel. The only way to fix it is to replace the whole LCD Panel which is very expensive (usually around $1000+ for 40" Sony). Unless the TV in under warranty, it is usually around the same price for a new TV.
Posted on Oct 05, 2009
Testimonial: "Thanks for the response. The service company Sony recommended told me it was probably the screen, too, and they quoted $1000."
welcomejee
  • 10594 Answers
SOURCE: Vertical Lines on Sony Bravia TV.
I'm afraid, its problem of LCD Panel (screen).
LCD Panel replacement is only solution for this problem and will cost you 70% of TV price, please contact nearest Sony service center for LCD Panel replacement.
Posted on Dec 13, 2009
What board is defective on a sony bravia KDL-XBR6 that has a colored vertical lines on the whole screen? No pictures on screen an its just a colored vertical lines...
T'Con board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 05, 2015 | Sony BRAVIA KDL-52XBR6 LCD TV
I have a Sony Bravia KDL-52XBR6 52". It has colored squares with vertical and horizontal lines on the entire screen, but still has a good picture. Is this repairable?
Looks like T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 26, 2015 | Sony Televison & Video
Vertical black line
HAVE YOU TRIED TO DEMAGNATIZE IT, LOOK IN MENU FOR THAT OPPION OR RESTORE FATORY DEFAULTS ,OR REST BUTTION
Jan 10, 2012 | Sony BRAVIA KDL-52XBR6 LCD TV
I have two sets of black horizontal lines going across my Sony Bravia KDL-52Z5100. If you make the picture smaller the lines extend into the black area that is not part of the picture. After the TV warms...
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Take care in solving the problem...
Aug 06, 2011 | Televison & Video
I have a Sony KDL-52XBR6. It has horizonal lines across the top of the screen. They appear to pulsate. The horizonal lines appear in groups, so that if, let's say, the screen was divided into columns, you...
Based on the information you've provided, I suggest that you update the TV with the latest System Software and check the operation. I've provided a link with the information to download System Software Update:
http://esupport.sony.com/US/perl/news-item.pl?news_id=273&mdl=KDL52XBR6
If the issue is unresolved, please follow the additional steps given below to troubleshoot the issue:
1. Make sure that you have connected the source to the Television properly and securely.
2. Unplug the power cord of the unit from the wall outlet for few minutes, then connect it to a different wall outlet and check the operation.
3. Connect the video source to a different input on the Television and check the operation.
4. Connect a different video source to the Television and check the operation.
5. Replace the connecting cable and check the operation.
6. Reset the TV to factory settings. To reset your TV to factory settings, turn the TV ON. Then, while pressing the UP ARROW or RESET button on the remote control, press the POWER button on the TV. The TV will turn itself OFF then back ON.
Dec 31, 2010 | Sony BRAVIA KDL-52XBR6 LCD TV
I bought a Sony BRAVIA KDL-52XBR6 LCD TV and 3 weeks later I broke the screen by accident, would you please let me know where can I buy a replacement screen? and how much it coast? or how much I can sell...
The screen cost more than the entire TV, better to get a new TV instead. You can try posting an add on Ebay to sell it for parts... Also you can try calling local repair shops in your area see if they may have a used LCD panel for your TV at a reasonable price.
http://tvtechwork.webs.com/
Nov 12, 2010 | Sony BRAVIA KDL-52XBR6 LCD TV
I have conntected my kdl 52 xbr6 to several computers most recently to a sony viao and an HP with HDMI output, and the TV produces the message output not supported...now these same computers work fine...
some of the newer tv's require drivers to be able to become a monitor if that's not what it was originally meant to be, try going to the sony site then under your model download the drivers.
Apr 08, 2010 | Sony BRAVIA KDL-52XBR6 LCD TV
I have a Sony 26 inch Bravia LCD tv model KDL-V26XBR1.It has thin vertical black and yellow lines about an inch apart across the whole display. Not noticeable from a distance but really see them up...
Well if the panel is bad it would not clear up in any situation, so its not the panel. most likely the t-con board or just poor connections inside. Julio Millenium TV in Las Vegas.
Dec 18, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Blue Vertical Lines on the screen
It means the optical block is going bad. Contact Sony support. They will sometimes warranty these even after the 1yr warrany has expired. Have your model and serial numbers handy.
May 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
