5OO+10 000/14% Description Quantity Amount 14% Assessor 500 10 000 Learner 200 5000 poe 500 4000 nd 1 1000
2 Suggested Answers
TechyDrood
  • 2072 Answers
SOURCE: PoE Cable for Polycom IP 500
Check if the switch uses active or passive PoE and the volts it pushes out
Active(PINS)1 2 3 4 5 6 7 8RX/DC+ RX/DC+ TX/DC- n/a n/a TX/DC-
Passive(PINS)1 2 3 4 5 6 7 8RX RX TX DC+ DC+ TX DC- DC-
Cat 5 cable9V < 30m cable length12V < 60m cable length
Max Ethernet cable length is 100m
Posted on Mar 22, 2012
Will the PoE Function of S2700/S3700/S5700 PoE Switches Be Affected When a 110 V Power Source Is Used?
When using Huawei power supply units, Huawei fixed switches supports 110 V AC input power. The power consumption of most powered devices (PDs) is 4 W to 5 W; therefore, 250 W and 500 W power supply units can provide sufficient PoE power for PDs.
NOTE:
All fixed PoE switches except the S2700-9TP-PWR-EI, S2750-20TP-PWR-EI-AC, S2750-28TP-PWR-EI-AC, S2751-28TP-PWR-EI-AC, S5700-10P-PWR-LI-AC, S5700-28P-PWR-LI-AC, S5700-28TP-PWR-LI-AC, S5700S-28P-PWR-LI-AC, S5701-28TP-PWR-LI-AC, S5700-52P-PWR-LI-AC, S5700-28X-PWR-LI-AC, and S5700-52X-PWR-LI-AC support double PoE power supply units.
Jan 10, 2017 | Computers & Internet
How do I add more inventory in restaurant pro express
In the OPTIONS screen, click ADMINISTRATIVE, then INVENTORY MAINTENANCE. After looking up the item you wish to change, click the INSTANT PO button in the lower right corner. Enter a description such as "INV ADJ" and hit ENTER. Enter amount of adjustment, not amount in stock. If you need to deduct, enter amount of deduction followed by the minus sign (-) then ENTER. Your IN STOCK amount should update immediately.
sysadmin@ccybernet.com
Feel free to email me with more details if need be.
May 12, 2014 | Pc America Restaurant Pro Express
Ex 5oo is killng batterys?
on my bike it is said to be the rectifier, no fixing it just toss and get a new rectifier. its not converting/reducing AC voltage as it should, so higher than spec surplus elec current gets dumped back into the battery, cooking it, also first check your battery ground it may be the problem
Nov 26, 2012 | 2000 kawasaki GPZ 500 S - GPX 500 R
Gas quantity in 1.5 ton window ac
Should have type and amount printed on the data plate. How do you know it's completely out and if it is completely out it sounds like a pretty significant leak and likely not worth the repairs. There's 4000 window units, no way I could tell you without more info.
May 20, 2012 | LG Heating & Cooling
Jan 14, 2012 | Polycom Poe Cable for Cisco For Use with...
The screen comes on for about 5 to 6 seconds then goes to a sleep like mode,,,but if i tap the input button the next mode i choose will do the same thing
It's very likely a problem with some of the capacitors in the power supply area. You can search for similar fixes here on this site. I'm ordering parts now for mine. Two of the eight tall/blue capacitors in a bunch have tops that are bulging (but I'll replace all eight since they're cheap). There's a pair of two in the middle of the same board on mine with bulging tops and there are four transistors in that same area that look like they got too hot. Most people seem to be getting away with only replacing the bulged capacitors but here is my total part list from digikey.com:
785-1106-1-ND quantity 2 (the D405-marked transistors) 785-1114-1-ND quantity 2 (the D408-marked transistors) P12389-ND quantity 8 (the 470uF capacitors) P12383-ND quantity 2 (the 220uF capacitors)
The total part list is about $7.50 with another $2.50 or less shipping. It's a pain to take apart, given the small connectors inside. The fix assumes you have soldering skills.
Go with these from digikey versus Radio Shack. They're rated for 220 degrees fahrenheit versus only 85 degrees and they're about a third less cost.
Feb 06, 2011 | Gateway FPD2185W 21 in. LCD Television
The monitor screen will not come up with the computer it turns on but will not boot up. The model number is fpd2185w
The problem is more often than not cause by the processor failure. But check the VGA cable for tamper or cuts.Try dismantling the board from all the serial bus, ATX wires and others.Clean up the whole system with a blower ( Remember to apply a good thin layer of heatsink compound paste on the processor and and re-install the whole peripherals. Then power on the system and try bringing up the BIOS setup. If that comes up fine, then re-install the OS an enjoy. Otherwise you need to get a new processor.
Sep 01, 2010 | Gateway Computers & Internet
Mn-5oo
Just open Internet Explorer and type http://192.168.2.1
When you get to the setup page of the router, look for Wireless tab, then Wireless Security. Select WPA-Personal or PSK and type your password on the passphrase or passkey box. Save the settings. That's it, your wireless network is secured
Apr 01, 2009 | Microsoft Broadband Networking MN-500...
Help
You can view and download the manual here. Instructions for using the self timer are on page 64.
Oct 10, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
