Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE Profile Convection oven - 3 buttons on the control panel stopped working - can I find schematics anywhere oneline?
  • 1,543 Answers
No schematics on line.
Take the key panel ribbon out of the connection to the control board and clean the end off with a pencil eraser. (some contacts are on one side, some on the other) Reistall and test. That takes care of the problem about 50 % of the time. If you still have the problem, replace the key panel.
Posted on Jul 25, 2009
My kitchen aid oven stopped working. The stovetop and LED readout Control Panel works fine. The convection oven and broiler do not work. Any suggestions?
Have you tried the "hard reboot" (e.g. unplug for several minutes then plug it back in)? I have a GE Profile oven that I need to do that with periodically otherwise it keeps the oven door locked!
Dec 25, 2014 | Kitchen Ranges
GE profile convection double oven. Model#jkp56w0w1ww 1.The touch panel on the Oven is off and none of the button works. There is not light or code in the display area. 2. The light inside the oven...
Oh, you probably got this fixed already. If it happens again, it helps to take the control panel off, insert paper towel folded up neatly and slotted into the ribbon (it absorbs the moisture which causes the ribbon to short out). Sounds crazy but it's true! I saved our family hundreds of dollars with a piece of paper towel!
Aug 18, 2013 | GE Ovens
My GE Profile Countertop Convection/Microwave Oven PEB1590DMBB Has stopped working.
It sounds like you may have a shorted cook relay on the control circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | General Electric PEB1590DMBB: Profile 1.5...
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    GE Profile PK916, Convc. elements stays on high
    he is right in what he says the heating element is feed from the main control board
    Oct 24, 2009 | GE Advantium 120 Convection/Microwave Oven
    My GE Profile Convection Microwave Oven - Convection not working
    Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
    Microwave Oven Basic Troubleshooting Tips
    heatman101
    uijjf
    Dec 02, 2008 | GE JVM1790SK Convection/Microwave Oven
    Convection fan not working
    Check for a bad fan motor or a jammed blade.
    Jan 01, 2007 | GE Profile JK915 Electric Single Oven
    GE Profile Spectra JGBP90 Gas Kitchen Range Logo
    211 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Mike Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
